ABA wrote:if it goes solid when you have clamps on the front flexi pipes its not the master cylinder has it got a b s
cherniy_chack wrote:ABA wrote:if it goes solid when you have clamps on the front flexi pipes its not the master cylinder has it got a b s
Yes.
I had a similar problem with my MK3.
The solution to the problem was to minimize the gaps between the rear brake drums and the pads.
dumper wrote:In your last post you’d fitted new pads have you run it up road and beaded them in by driving with your foot on the breake till pads warm up and you can smell them then let them cool down and do it again till they are beded in you will have more travel on break pedal
Chuggy wrote:If clamping the front makes it solid but clamping the rear makes no difference, I would suspect the seal for the rear section of the master cylinder.
grumpygramps-2007 wrote:i was advised when you push the pads back to open the bleed nipple abit to let the pressure off.saves the mastercylinder some how. gramps.
vanfox wrote:I just changed front pads on Friday, pushed the pistons back fitted the pads and built up the brake, two or three pushes and all is well, brakes working both sides. Have you tried clamping just one front hose at a time?
cherniy_chack wrote:If there is no air in the brake system, the large free travel of the brake pedal is associated only with large gaps in the working brakes.
In the front brake mechanisms, the gaps between the pads and discs are determined only by the elastic deformation of the rubber sealing rings of the front brake cylinders and, by definition, can not be large.
https://www.google.com/url?sa=i&rct=j&q ... 1247204253
https://www.youtube.com/watch?time_cont ... 4fAPpj3p48
In the rear drum brakes, the gap between the pads and drums is determined by the compression springs and various additional mechanisms to minimize the gap.
At the Transit MK3 ... MK5 this additional mechanism is often defective.
Therefore, in the absence of air in the system, the brake pedal has a large free stroke.
fuzzedup,lift the parking brake lever, make sure that the rear wheels are locked by the parking brake and depress the brake pedal two times.
For the first time the free stroke can be large, the second one must be normal.
If so, then a large clearance in the rear brakes.
I wish you success!
