2.5DI no lift pump
2.5DI no lift pump
Postby ceurieusneus » Thu May 10, 2018 7:24 am
For the Transit Brains
My MK3 has no fuel lift pump, and no hand pump on the fuel filter... :mrgreen:
Bosch pump.
What's the best way to change the fuel filter, preferable without getting air in the high pressure system. :?
Thanks guys
Writing was not invented to look for spelling errors :wink:
Ford Anglia '62, Mercedes 200 '86, Transit ambulance/camper '88, Mercedes CE300 '89, caravan Puck '75
My ambulance conversion
ceurieusneus
Re: 2.5DI no lift pump
Postby dumper » Thu May 10, 2018 8:03 am
Fill new filter up with clean fuel keep tapping it to get air bubbles out re fit make sure you get it on right to get a good seal then start engine with at least half revs for a minute or so and you should be ok
Postby vanfox » Thu May 10, 2018 10:53 am
I would add: Before removing the filter get the engine warm so that if you do get air into the system you don't have to spend time churning over a cold engine on the starter.
vanfox
Postby dumper » Thu May 10, 2018 11:05 am
vanfox wrote:I would add: Before removing the filter get the engine warm so that if you do get air into the system you don't have to spend time churning over a cold engine on the starter.
Cheers vanfox I forgot that bit I usually do my filter straight after I do oil change
Postby V184 » Sun May 13, 2018 12:57 pm
Just fill the new filter with diesel & start the engine & let it idle, the Bosch pump holds a quite a bit of fuel
V184
Postby ceurieusneus » Thu May 17, 2018 10:18 pm
Thank you guys
Followed all your advices...
Peace of cake...
No problems at all :D
Anyhow, i would feel much more secure if my transit had a lift pump...
What about putting an electrik lift pump somewhere near the fuel tank?
Anybody has any expeariance with it? 8)
ceurieusneus
Postby Chug » Thu May 17, 2018 11:44 pm
Mines got no lift pump either, I just fill the filter and start with with a little throttle, although I did use a 12v pump to prime my injection pumps when I swapped two of them recently.
Chug
Postby Stule » Mon Jun 11, 2018 9:49 pm
You are better without one trust me i had a two fails with them both on long way from home. And on transit the fuel tank is close and fuel pump can drive it peace of cake. Only you watch when changing filter to fill it and thats it and have a big syringe close if it cought some air and no problem
Stule
Postby cherniy_chack » Tue Jun 12, 2018 5:05 pm
Before replacing, fill the new fuel filter with fuel.
Have at least half the fuel tank.
cherniy_chack
