For the Transit Brains
My MK3 has no fuel lift pump, and no hand pump on the fuel filter...
Bosch pump.
What's the best way to change the fuel filter, preferable without getting air in the high pressure system.
Thanks guys
vanfox wrote:I would add: Before removing the filter get the engine warm so that if you do get air into the system you don't have to spend time churning over a cold engine on the starter.
