1996 2.5tdi minibus valves hitting pistons
Postby Hazepurp » Fri May 11, 2018 12:47 pm
Hi all
My engine was turned out of time accidently and four rods bent two rockers.
I have replaced rods n rockers timed it up from TDC according to the haynes manual with all 3 pins locked and engine turns fine until I try to do valve clearances. All exhaust valves hit. ...inlet are ok.
Very confused. .....
Hazepurp
Re: 1996 2.5tdi minibus valves hitting pistons
Postby dumper » Fri May 11, 2018 7:40 pm
The only thing I can think of been wrong you have not pinned it up right or have you set the tappits to the correct clearance and adjusted useing the sequence in the book standard adjustment sequence does not work on a di
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby ceurieusneus » Fri May 11, 2018 8:18 pm
dumper wrote:The only thing I can think of been wrong you have not pinned it up right or have you set the tappits to the correct clearance and adjusted useing the sequence in the book standard adjustment sequence does not work on a di
Could you tell me, what you mean with standard adjustment sequence?
Thanks!
Writing was not invented to look for spelling errors :wink:
Ford Anglia '62, Mercedes 200 '86, Transit ambulance/camper '88, Mercedes CE300 '89, caravan Puck '75
My ambulance conversion
ceurieusneus
Postby gotgcoalman » Fri May 11, 2018 9:28 pm
Thanks!
it's the old rule of 9. Think it was for the 1,3,4,2 firing sequence.
1 open set 8
2 open set 7
3 open set 6
4 open set 5
Too bloody quiet :shock:
gotgcoalman
Postby Chug » Fri May 11, 2018 10:59 pm
The engine turns two complete revolutions without valves hitting and pins fit in again?
Then when you set valve clearances it locks when turning?
What are you setting valve clearances to?
How did the 'accident' happen?
Chug
Postby ceurieusneus » Sat May 12, 2018 6:54 am
Thanks!
1 open set 8
2 open set 7
3 open set 6
4 open set 5
Thanks, this gives me a good idee how they had f....d up the clearance off my outlet valves ... some had more than 1mm :mrgreen: :evil:
I am pretty deaf (sound of big engines) so I run this engine for 2 years, without notice, lucky the MOT man told me. :oops:
Previous, (long time ago) I always used on my cars the "mirror" system.
ceurieusneus
Postby dumper » Sat May 12, 2018 7:38 am
Just read my reply and it maybe misleading to set the tappits do not use the 1from 9 Method use the table in the Haynes manual :(
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby gotgcoalman » Sat May 12, 2018 8:21 am
Correct way........
valve clearances
Inlet 0.20mm
Exhaust 0.38mm
valves fully open valves to adjust
1 and 6................... 4 in and 7 ex
2 and 3................... 5 ex and 8 in
4 and 7....................1 ex and 6 in
5 and 8....................2 in and 3 ex
firing order on a Di is 1,2,4,3
gotgcoalman
Postby ceurieusneus » Sat May 12, 2018 6:41 pm
Yes Yes,
I was not mislead... not at all 8)
I had set the valve clearance as in the Haynes.
But now, I suspect the previous owner to have used the rule of 9. :(
I can not explain otherwise, why the clearance of the exhaust valves was so enormous... :x
Thank you guys for the explanation. :D
ceurieusneus
Postby Hazepurp » Fri Jun 15, 2018 4:51 pm
Hi everyone thank you so much for your replies! I had to go away for a bit re late reply but yes I was a numpty and had mistaken a shallow notch on the flywheel (that did lock the crank) with the actual hole for the pin! All clearances/timing now correct.
Now I have a new problem. .....she turns and turns but will not fire :( I have bled the system and have no fuel leaks but have the noise of air escaping somewhere down the back of the cylinder block I'm still looking for the source. .......but I'm getting despondent now.......any ideas guys? X
Hazepurp
Postby gotgcoalman » Fri Jun 15, 2018 7:35 pm
so it'll turn over no problem but not fire?
you have fuel up to the injectors?
Charge/use jump leads and squirt wd40 or similar into the air box and see if it tries to start.
have you disturbed any wiring?
the air escaping noise could be a valve issue. valve open on the compression stroke.
check they're set correctly.
gotgcoalman
Postby Hazepurp » Fri Jun 15, 2018 8:14 pm
Hi
Fuel up to the injectors yes. Wants to fire with brake cleaner in the airbox but stalls immediately.
Checked all wiring ....
When you say check the valves do you mean clearances? It wooshes in time with the pistons. ..Once every four strokes....like a steam engine almost. ...just can't see where from! ...is it sucking air in rather than blowing it out?
Thanks for your time :)
Hazepurp
Postby vanfox » Fri Jun 15, 2018 8:52 pm
I recall a similar whooshing sound a while back. Check the injector seals. Have you had them out? Are all the securing bolts tight?
vanfox
Postby gotgcoalman » Sat Jun 16, 2018 11:19 am
Yep could be 1 or more of the valves not closing fully.
+1 on checking injector seals.
squirt some soapy water around the base of each injector and look for bubbles forming.
gotgcoalman
