starter motor circuit 97 transit 2.5Di smiley
Postby 97transit2.5D » Mon May 21, 2018 9:13 am
Hi MK5 gurus
recently replaced a starter motor with a new one from BOSCH. why?Had the problem of the starter clicking..ie faulty starter solenoid.
all connections are tight, earth cleaned and tight.
starting sequence is >>turn key until heater light goes>> out then turn key completely>>start,
now with new starter still get occasional click. no start. dont think it is starter solenoid
question: is there some some of relay inbetween the starter and the ignition circuit..
battery is fully charged,out temp is 10 deg positive. fresh diesel
thanks Rick ,New Zealand
97transit2.5D
Re: starter motor circuit 97 transit 2.5Di smiley
Postby Noctule » Mon May 21, 2018 10:53 am
Check the crimped connections on the starter cable and engine earth. I've cables come loose in the crimps on the Transit and the hearse, and a tug or twist on a cable has temporarily solved the problem.
Mat
2000 Mk5 HiCube self-build camper
- 2.5tdi 4EA with EPIC-to-Bosch conversion
- DRW with 16" rims
- Mondeo instrument cluster
- Lunar Meteorite interior
2006 Mk7 115t350 van (cheap tax tramp)
Previously...
Mk5 100 swb Custom
Mk5 190 lwb x3
Noctule
Postby MinorMatt » Mon May 21, 2018 12:05 pm
Depends on the age, early smileys have a relay on the drivers side (rhd) inner wing for the starter and its common for the terminals etc to corrode and fail
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby ceurieusneus » Mon May 21, 2018 4:03 pm
I put in a decent extra relay.... battery - fuse - relay - solenoid
Relay is activated by the (old) solenoid cable.
No more clicks. :D
Make sure everything is safe
Do not forget to use a FUSE!
Writing was not invented to look for spelling errors :wink:
Ford Anglia '62, Mercedes 200 '86, Transit ambulance/camper '88, Mercedes CE300 '89, caravan Puck '75
My ambulance conversion
ceurieusneus
Postby cherniy_chack » Mon May 21, 2018 6:32 pm
If you turn the key,but the solenoid does not on,a problem in the starter circuit-ignition switch, relay, wire.
If the solenoid turns on while turning the key, but the starter motor does not rotate, then the problem may be in the power wires from the battery to the starter or from the battery to the engine block.
cherniy_chack
Postby 97transit2.5D » Thu May 24, 2018 6:46 am
looking for a relay..this is a 1996..build...if i send a photo..is it on the right...new zealand is RHD..below right of the steering wheel is a fuse box...is it in there..or is it in the engine bay...????..its doing it more often...two turns of key nothing just click..brand new bosch starter remember..then third turn starts..those cables to starter end up in a junction close to battery..how do you troubleshoot this???Rick
97transit2.5D
Postby Chug » Thu May 24, 2018 8:37 am
If fitted its usually under the bonnet on the inner wing, follow the main lead from the battery positive terminal to the starter.
Make sure all connections are clean and tight.
Also try clamping a jump lead from the battery positive terminal direct to starter to bypass the main lead and see if it fixes it, if not then use another smaller wire from battery positive to the small terminal on the starter solenoid.
Chug
Postby cherniy_chack » Thu May 24, 2018 4:03 pm
I'm a rough mechanic and check the starter by simply closing the receiving power bolt on the solenoid with the solenoid's control contact.
If the starter is working normally with such an inclusion, the problem is in the control wiring.
If a bad problem exists in the starter itself, the battery or the power wiring of the starter.
cherniy_chack
Postby 97transit2.5D » Sat May 26, 2018 12:01 am
Hi
I looked in my Haynes manual..page WD18-19 book 3019 (thanks John Haynes!! RIP)
shows a starter relay...will hunt for it after the come back from football....could be inside engine bay...
Chuggy..you mentioned..If fitted its usually under the bonnet on the inner wings..whats a inner wing??
thanks Rick
97transit2.5D
Postby Chug » Sat May 26, 2018 12:35 am
Just follow the leads from the starter and you will find it, if its got one fitted.
Chug
Postby 97transit2.5D » Sat May 26, 2018 10:23 am
I think i am looking for a cube type relay...they feature in my drivers cabin fuse box...might even try to remove a few there...but
this puppy should be in the engine bay close to the battery and prob near the main engine fuse box...as diag shows relay might be protected by a beefy 60A fuse..that is IF IT WAS ADDED...but why have a cct diag
if it does not exist and i doubt that the starter solenoid would come straight off an battery via a fuse.
also included what an OLD type of relay might look like in a mk3 or mk4
97transit2.5D
