Hi MK5 gurus
recently replaced a starter motor with a new one from BOSCH. why?Had the problem of the starter clicking..ie faulty starter solenoid.
all connections are tight, earth cleaned and tight.
starting sequence is >>turn key until heater light goes>> out then turn key completely>>start,
now with new starter still get occasional click. no start. dont think it is starter solenoid
question: is there some some of relay inbetween the starter and the ignition circuit..
battery is fully charged,out temp is 10 deg positive. fresh diesel
thanks Rick ,New Zealand
