Knocking from front suspension
Postby VMH » Sat Jun 02, 2018 11:50 pm
Hi.
My 1995 smiley has a knocking noise from the left hand front end over bumps which was intermittent, came and went, but is now getting quite bad.
I replaced the anti roll bar bushes which were badly worn but still doing it.
I have jacked the front up and checked all the joints and bushes but can't find anything wrong except for a creaking noise from the suspension strut on that side when I turn the steering.
It did have a badly repaired front end smash some time before I bought the van and is sitting lower on that side. I am wondering if the strut could be bent?
It goes through the MOT no problem every year.
Anyone got any ideas?
VMH
Re: Knocking from front suspension
Postby davetheshrew » Mon Jun 04, 2018 6:56 am
strut bushing or coill snapped at the to, im going for bushing though.
Drab green Transit 190 L High top minibus
turbo conversion with toyosports intercooler
davetheshrew
Postby knoba » Mon Jun 04, 2018 9:14 am
Loose bumpstops inside the top spring coil turrets...
knoba
Postby V184 » Mon Jun 04, 2018 7:57 pm
Quite common for the coil spring to come out the top rubber mount and hit the crossmember
V184
Postby VMH » Sun Jun 10, 2018 10:42 pm
Ok Thanks. Will have a look at that.
We do live at the end of a mile long dirt track.
VMH
Postby cherniy_chack » Mon Jun 11, 2018 6:55 am
Cuff and knock in the front suspension can do anything.
Opening is half a square. :lol:
cherniy_chack
