Morning Guys,
Since some time I can recognise a disturbing behaviour of my brake pedal. When I press it, it keeps traveling down, both with the engine off as well as running (it travels faster with the engine running, of course).
The strange thing is, I have driven at least 300 km like this and there is no fluid loss at all in the reservoir. Could it be a leaking master cylinder? But if so, where does the brake fluid go considering the fluid level in the reservoir does not change?
Here you can see an exploded view of the master cylinder. Car is MK4 1992 reg, non-ABS:
http://www.catcar.info/ford/?lang=en&l=bWFya2V0PT1ldXJvfHxjYXRfaWQ9PTQyNXx8Y2FiYnI9PURZfHx0aGs9PTB8fHN0PT02MHx8c3RzPT17IjIwIjoiRXVyb3BlIiwiMzAiOiJUcmFuc2l0IERZIDE5OTEtMTk5NCIsIjQwIjoiRSBCcmFrZXMgLSBCcmFrZSBQaXBlcyAtIFdoZWVscyIsIjUwIjoiRTAyIEJyYWtlcyAtIEJyYWtlIFBpcGVzIC0gV2hlZWxzLk1hc3RlciBDeWxpbmRlciBBbmQgQnJha2UgQm9vc3RlciIsIjYwIjoiRTAyMDEwIE1hc3RlciBDeWxpbmRlciAmIEJyYWtlIEJvb3N0ZXIifXx8YWxwaGE9PUV8fGdyb3VwPT1FMDJ8fHNlY3Q9PUUwMjAxMHx8c2V0PT1EWUUwMnx8aW1nPT1aMDAxMjMxNTAwfHxmMTI9PTEwNTE3OTIwKzA%3D
Cheers, Kai
