99 mk 5 95 amp alternator problem
Postby dick » Thu Jun 07, 2018 9:10 pm
hello all, the charge light on the dash doesn't come on at all, although the alternator does not charge , i've swapped it out for a spare i have but still nothing, i've tested the bulb and its good, i have 12v on the ribbon to the bulb and have 11v the the other side of the bulb, but i guess this should be earthed ?? to light the bulb, on the alternator what do the two wires on the push connector do, cheers
dick
Re: 99 mk 5 95 amp alternator problem
Postby gotgcoalman » Thu Jun 07, 2018 9:27 pm
Mine packed in yesterday.
No light on the dash to indicate low charge.
Is yours like this one with the 2 wire plug ?
Volt meter in cab showing battery voltage and dropping as brakes and indicators were used to get home.
At 1 point it started charging 13.8v shown on the volt meter.This was short lived :(
got home and battery showed 12.1v.
Alternator dropped off at auto electric place for diagnostics/repair.
replacement is between £100-£140 new :( :(
I'll find out tomorrow if it's beyond economic repair :shock: :shock:
Too bloody quiet :shock:
gotgcoalman
Postby dick » Thu Jun 07, 2018 9:44 pm
yes thats the one, no charge out of it at all, i did fit a recon one but that was the same, i thought it was a duffer but now think its Something more????
dick
Postby dick » Thu Jun 07, 2018 9:46 pm
i can't get the fact that the charge light does Nothing ??
dick
Postby gotgcoalman » Thu Jun 07, 2018 9:53 pm
Can't remember off hand.
but
regulator/rectifier/diode in the alternator controls the charge/low charge light.
If that goes then the bulb won't light up.
Could also be fuse/wiring :(
gotgcoalman
Postby Bruce e » Thu Jun 07, 2018 11:45 pm
Could be the small wire from the battery to the alternater that supplies power to excite it so it works. Had the same problem with a Hino truck
Sent from my SM-G390Y using Tapatalk
Bruce e
Postby gotgcoalman » Fri Jun 08, 2018 10:35 am
Just been on to auto electric place.
Regulator is fubar.
testing + repair £60.
gotgcoalman
