MK3 Gearbox Issue / Concern
Postby Steve.w » Fri Jun 08, 2018 10:30 am
Hi all,
1989 G reg Ford Transit Autosleeper 2.0 petrol 5 speed manual -
Basically it shudders badly in reverse and the thrust bearing is noisey until you put your foot down on the clutch, time for a new clutch kit im thinking,
Now then …. my concern is ive looked underneath at the gearbox and it appears to me as if something is missing?? im no expert but any help or advice would be great.
ive uploaded a video onto youtube which I thought may help better to understand my concern rather than me try to explain it..
https://youtu.be/kQbGp7j2aUs
Thankyou.
Steve.w
Re: MK3 Gearbox Issue / Concern
Postby gotgcoalman » Fri Jun 08, 2018 12:50 pm
thin pressed metal cover?
Too bloody quiet :shock:
gotgcoalman
Postby ABA » Fri Jun 08, 2018 12:55 pm
you've got a metal plate missing also the leg that your engine rest on the rubber at the bottom looks like the bottom nut is ether loose or missing
ABA
Postby ABA » Fri Jun 08, 2018 2:20 pm
flywheel cover for pinto engine
theres one on ebay for £ 35 at the momment
ABA
Postby V184 » Fri Jun 08, 2018 2:44 pm
thats the wrong cover :roll: :roll: :roll: . you need to get the box out & replace the missing bolts in the adapter plate as there prone to snapping the lugs off the engine block when missing. also the lower plates missing
V184
Postby Steve.w » Sat Jun 09, 2018 12:15 pm
thanks for all you comments / help !! :D
Steve.w
