Windscreen rubber
Windscreen rubber
Postby finn_mccool » Sun Jun 10, 2018 2:31 pm
Two questions.
1. What's the name of the black rubber trim which covers the edges of the windscreen channel prior to installing a new windscreen called?
2. Where can I get it?
finn_mccool
Re: Windscreen rubber
Postby finn_mccool » Sun Jun 10, 2018 7:22 pm
Never mind - found it!
finn_mccool
Postby cherniy_chack » Mon Jun 11, 2018 7:03 am
This rubber is called the "windshield seal".
Under the rubber, when it comes to the windshield (front), a layer of black sealant is applied.
Before applying the sealant, the window opening is treated with a primer to improve the adhesion of the sealant to the paint.
Before the primer, the window opening is degreased by any solvent that does not damage the paint.
cherniy_chack
