rear brake shoe replace
Postby escort » Sun Jun 10, 2018 9:42 pm
hi all
ive got a duetto lwb 1996 van that i need to replace a rear brake wheel cylinder and brake shoes
the haynes manual says i need to remove half shaft and hub to do this ???
can the shoes and cylider be replaced without removing hub? thanks george
george
escort
Re: rear brake shoe replace
Postby twin wheel camper » Sun Jun 10, 2018 11:23 pm
If it’s 15 inch wheel model I just changed mine and didn’t remove anything other than the shoes and brake cylinders, I can’t comment on the smaller 14 inch type but the heavy axel you definitely don’t remove half shafts.
twin wheel camper
Postby cherniy_chack » Mon Jun 11, 2018 6:50 am
On the 14 "version everything changes without problems.
cherniy_chack
Postby dumper » Mon Jun 11, 2018 8:20 am
On the twin wheel or the single wheel 6 stud axel it all depends on if you can get the drum off most of the time it’s easier to take the complete hub off
