Hondekop wrote:When the whole van is melted to a puddle, that is the end
cherniy_chack wrote:The fact that the engine needs to be removed and disassembled is unambiguous.
The options are:
1-cranked the crankshaft.
Possible complication is the cylinder block.
2-destruction of the piston, piston pin and subsequent destruction of the connecting rod and / or cylinder block.
3-destruction of the clutch parts.
This is the easiest option.
The first two are engine replacement.
Chuggy wrote:I just read the thread and when I saw oil light came on and the engine stopped I thought it might end badly,
is it donking low down in the bottom of the engine as in main bearings?
