MT75 differential - oil change?
Postby jonb1985 » Wed Jun 13, 2018 11:18 pm
Hi all, thanks to this forum I've today established that I have an MT75 gearbox fitted to my 1991 Autosleeper Legend (based on a Transit mk3 petrol).
I've just ordered MT75 oil to give it an oil change.... But now I'm wondering if I ought to do the diff too - Would this be wise? 48000 miles on the clock and no history of a change previously.
If so which oil grade should I use - can I use the same MT75 oil? I got contradictory info from a google search.
Thanks in advance.
Jon
jonb1985
Re: MT75 differential - oil change?
Postby Chug » Wed Jun 13, 2018 11:30 pm
The diff doesn't have a drain plug so you will have to suck it out of the filler plug hole with a sump oil sucker, big syringe, or similar, the oil you want for the diff is EP 80-90.
Chug
Postby vanfox » Thu Jun 14, 2018 10:48 am
Does anyone ever change the diff oil? Maybe just top it up if needed. Why was a drain plug never fitted?
I guess some diffs are running on 20 yrs old oil?
If you want to change it I'd do it after a looong run when the oil is warm and thinner then suck it out.
EP 80-90 it is. Clean the crap away from the filler.
vanfox
Postby Hondekop » Thu Jun 14, 2018 11:37 am
vanfox wrote:Does anyone ever change the diff oil?
Yes, I did. The oil may still be degraded by temperature, moisture, oxidation, grinding between the gears etc.. I doubt it will have the same wear and corrosion inhibiting properties it had originally.
vanfox wrote:I guess some diffs are running on 20 yrs old oil?
I think you're right.
1992 MK4 LWB van, 2.5 TD 101 HP
Hondekop
