1997 engine question
Postby Stevebrookman » Fri Jun 15, 2018 6:22 pm
Afternoon all,
Going to look at a1997 Smiley motor home. It's done 33000 miles. Anything that stands out mechanically with these? I have read that they are quite reliable. Bodywise I know what to look for - but have never had a diesel before.
Any advice greatly appreciated.
Steve
Stevebrookman
Re: 1997 engine question
Postby gotgcoalman » Fri Jun 15, 2018 7:20 pm
If you know the usual rust places then mechanically it's just service history on such a low milage motor.
Timing belt should have been changed on age rather than milage.
Too bloody quiet :shock:
gotgcoalman
Postby Stevebrookman » Fri Jun 15, 2018 8:23 pm
Thanks.
Will check to see if changed.
Regards
Steve
Stevebrookman
Postby dumper » Fri Jun 15, 2018 8:33 pm
Yes rust and timeing belt
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Stevebrookman » Sat Jun 16, 2018 8:05 am
Thanks.
Will have a look and report back.
Regards
Steve
Stevebrookman
Postby Stule » Sun Jun 17, 2018 10:25 pm
Take a look for rust at usual places wings, bottoms and sills. And also take a look which pump it have if its a turbo engine and pull strenght.
Stule
Postby Hondekop » Mon Jun 18, 2018 2:33 pm
If it's a turbo, the EPIC injection pump is the major weak point.
1992 MK4 LWB van, 2.5 TD 101 HP
Hondekop
Postby Stevebrookman » Wed Jun 20, 2018 7:39 pm
Thanks-having a look at the weekend. It's a turbo so likely to be the EPIC pump. Are these very troublesome?
Regards
Steve
Stevebrookman
Postby Stule » Wed Jun 20, 2018 8:26 pm
Yes they are, best solution is to put Bosch pump in from the NA engine and no more problems, also you can then ditch the ecu and all electronics sensors etc. Result is much more safer van with no more problems. You cant do all of this if its Auto Transmission.
Stule
