Indicators flashing fast
Postby finn_mccool » Sat Jun 23, 2018 10:21 pm
Just doing the final pre-MOT bits, and noticed the indicators are flashing fast (like they would if a bulb had gone). This happens for both directions.
All the bulbs are present, functional and flashing, just fast.
When I use the hazards, they flash at the correct speed.
I've had the indicator stalk out (as suggested from other posts), cleaned all the contacts out and given it a general clean, but to no effect.
What next? Do I need to bite the bullet and try a new relay?
finn_mccool
Re: Indicators flashing fast
Postby Chug » Sat Jun 23, 2018 10:57 pm
Guess its a tenner and try the relay
Chug
Postby finn_mccool » Thu Jun 28, 2018 11:17 pm
New relay solved the problem. Hooray!
Incidentally, it wasn't a Ford one. It was for a Land Rover, but rated for same wattage and same pin layout. And only £6.
finn_mccool
Postby Chug » Thu Jun 28, 2018 11:45 pm
Good result :D
Chug
Chug
