turbo sump fitting size
Postby davetheshrew » Fri Jul 06, 2018 9:58 pm
I managed to get an original oil outlet pipe for my turbo but ant seem to figure out what size fitting I need to add to the sump, any tips would be great, thanks.
Drab green Transit 190 L High top minibus
turbo conversion with toyosports intercooler
davetheshrew
Re: turbo sump fitting size
Postby vanfox » Sat Jul 07, 2018 11:35 pm
This has been covered in the past, use the search feature, top right.
vanfox
Postby F111ORY » Mon Jul 09, 2018 8:25 am
Its m20 take your flexible hose to a hydraulic supplier and they will sell you a fitting that screws into it, assemble the turbo on the engine with the fitting in the return pipe to position it correctly ( you may want to cut off unwanted threads) on the sump, tack weld it and then remove the flexible pipe before completing the welding, then drill through.
F111ORY
Postby cherniy_chack » Tue Jul 10, 2018 6:06 pm
The socket (fitting) on the pallet is threaded M20x1.5.
Tomorrow I will clarify.
The fitting is installed on the sump wall by the drain hose, welded, then the hose is removed and the fitting is finally welded.
Then a hole is drilled in the wall of the pallet.
cherniy_chack
Postby cherniy_chack » Thu Jul 12, 2018 6:36 pm
M20x1.5
cherniy_chack
