What size steel for chassis repair
Postby po79 » Tue Jul 17, 2018 2:32 pm
Hi guys,
As title really, what thickness steel do you use for the chassis.
I'm thinking 2mm.
Plus any one recommend a cheap supplier, I'm in Bridgend South Wales.
Also I'm replacing the spring hanger osf any know of a good thread on here that I could read, it looks straight forward but sometimes there are ways to make these things easier that you don't find out until your done the done yourself.
Cheers,
Po79.
po79
Re: What size steel for chassis repair
Postby gotgcoalman » Tue Jul 17, 2018 6:13 pm
2mm is fine :D
Best place for cheap metal is usually small local engineering firms.
They usually let you rake through the scrap/off cut bin in exchange for a few quid.
Too bloody quiet :shock:
gotgcoalman
Postby po79 » Wed Jul 18, 2018 5:04 pm
Thanks for the reply.
I'll try to find some local companies,.
Po79.
po79
Postby INTRANSIT » Wed Jul 18, 2018 9:25 pm
Mk7 2.2 85ps Fwd 2008 poverty spec
INTRANSIT
