V184 wrote:loosen the bleed nipples and let it "naturally bleed" then tighten them all
dumper wrote:start furthest away from the master cylinder
rebuilder86 wrote:and i made a little jar with 2 pipes coming out of it, prefectly sealed, and i stick one end on engine vacuum and one on the bleed nipple and suck the fluid through wiht the engine at idle (highest vacum)
