overhaeting
Re: overhaeting
Postby cherniy_chack » Tue Aug 07, 2018 6:47 pm
wobbles wrote:i just dont know ....
I don`t know too.
But I think that the reason in the thermostat.
The design of the thermostat is such that over time the thermoactive substance leaks from the ampoule and it begins to open at a higher temperature and the valve thermostat moves less.
Replace the thermostat with a new one.
The price of the thermostat is up to 10 pounds sterling.
It can be replaced without draining completely the liquid from the cooling system.
cherniy_chack
Re: overhaeting
Postby wobbles » Tue Aug 07, 2018 7:25 pm
yeah sound advice . i will order one right now !!
cheers
wobbles
Re: overhaeting
Postby gotgcoalman » Tue Aug 07, 2018 8:50 pm
In the meantime.
Take the stat out and use the van normally.
If the gauge barely moves with no stat in then it was causing the overheating.
heater won't blow very warm though :wink:
Too bloody quiet :shock:
gotgcoalman
Re: overhaeting
Postby pedracer » Tue Aug 07, 2018 9:42 pm
I have an electric fan, why folk keep the viscous units is beyond me... Anyway, even in the hot weather, running at 3 tons (it's a 4x4 campervan), it's staying bang in the middle and not used the electric fan, So I would hazard a guess that something is either restricting your water or not pumping it correctly. The water should naturally thermo- syphon around the engine, but this my not be enough to stop it going towards the red. Need to check how much water is being pumped, how, I don't know.
pedracer
Re: overhaeting
Postby rebuilder86 » Wed Aug 08, 2018 12:13 pm
I litteraly just came on here to post, the exact same post.
2.5 td 100 PS, in perth australia, currently really cold wet weather, and for the first time ever, the gauge went up to 3/4 the way to red last week.
And tonight, while it was very cold out, the gauge went up to midway, wich it never does unless climing long long hills.
Mine I suspect has no thermostat, as the temp gauge varies considerably up and down during the journey, and usually sits way tooo cold, like just touchign the operating range line, almost at the very left.
Having no thermostat, actually causes big problems.
No thermostat means no back pressure on the water pump, which creates cavitation (aeration of the water aroundthe fins of the water pump) which increases corrosion and wear on the vanes in an exponential amount.
My fear is that im probabyl experiencing this, but it could be that
a. the rain is getting in to the electronics and shorting the temp sensor a bit, or
b. the rain is getting into a connector perhaps just creating a good contact in a slightly coroded connection to the temp sensor, indicating a more correct warm temp when its raining.
Nothing felt remarkably hot when i had the really hot situation, however i got home, and found i needed about 2 litres of coolant (water) to bring it up to the normal mark, and it hasnt crept that frar since then. The creep up was incredibly fast, like i watched the gauge move.
So theres some food for thought, its a complicated subject with far too many variables.
rebuilder86
Re: overhaeting
Postby wobbles » Tue Aug 14, 2018 6:52 pm
new thermostat arrived in the post . will fit tomorrow and see what happens.....
wobbles
Re: overhaeting
Postby F111ORY » Wed Aug 15, 2018 11:29 pm
gotgcoalman wrote:In the meantime.
Without the thermostat to block the bypass ( that's what the second plate on the thermostat is for!) when the engine gets hot, the engine WILL overheat!
F111ORY
Re: overhaeting
Postby gotgcoalman » Wed Aug 15, 2018 11:51 pm
I'll take mine out just for shits and giggles to see what happens. :shock:
gotgcoalman
Re: overhaeting
Postby ABA » Thu Aug 16, 2018 1:44 pm
V184 wrote:faulty gauge ?
I would have said faulty sender unit
ABA
Re: overhaeting
Postby V184 » Thu Aug 16, 2018 7:38 pm
Post 1 he had changed it :wink:
V184
Re: overhaeting
Postby gotgcoalman » Fri Aug 17, 2018 10:36 am
So I've run with no thermostat this morning delivering euro pallets. Last run with approx 1200kg on the back of the motor. Did 60 miles so the motor should be as warm as it's going to get.
Note to self. Clean the dash you dirty sodImage
Sent from my Plus E using Tapatalk
gotgcoalman
Re: overhaeting
Postby wobbles » Mon Aug 20, 2018 4:11 pm
update ..... so i fitted a new thermostat ....and yes it has helped alot ....... did few hours driving over the weekend and the needle almost didn't move from centre!!!
only thing now is there seems to be a new problem ,,,, high idle for some reason about 1500 rpm !!!! any ideas ?
cheers people
wobbles
Re: overhaeting
Postby V184 » Mon Aug 20, 2018 4:46 pm
Wiring/plug to temp sensor
V184
Re: overhaeting
Postby wobbles » Mon Aug 20, 2018 6:43 pm
there is two temp sensors in the thermostat housing , i have already replaced on .....so yeah i will replace the other alright and see what happens
wobbles
Re: overhaeting
Postby twin wheel camper » Mon Aug 20, 2018 9:52 pm
It will be the sensor at the front of the housing, that’s the TD temperature sensor the other is just the gauge.
That sensor isn’t on a non TD only the TD di’s.
twin wheel camper
