1999 2.5D OVERDRIVE NOT WORKING
Postby torin246 » Fri Aug 17, 2018 10:35 am
Yo, Hello From New Zealand,
Has anyone had any issues with there overdrive not engaging?? Any tips, as where to start?
I have been told it needs a new Transmission Modulator,,, What do you guys think??
Look forward to hearing from you.
torin246
Re: 1999 2.5D OVERDRIVE NOT WORKING
Postby torin246 » Fri Aug 17, 2018 11:54 am
Ok have done allot of searching on the sight. I am going to start with adjusting the Belt,,
Although if it was that the belt needs tightening wouldn't, there have been Gradual slipping,, Not all of a sudden no OD,
Makes me think it is a solenoid issue
torin246
Postby V184 » Fri Aug 17, 2018 4:25 pm
torin246 wrote:Ok have done allot of searching on the sight. I am going to start with adjusting the Belt,,
Belt :? :? :?
V184
Postby MinorMatt » Sat Aug 18, 2018 12:36 pm
No overdrive on a 99 (or 89) transit...
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
