Hi,
This is late if you're working on it, and you may have your answers already, but been looking at this site and AndyG plus Jim and others have been great help to me over the years. Great pump when going well, and some things are simple. Replacing the external square seal is one, you don't disassemble the pump (tip; when removing the pump look at it straight away carefully to identify where on the pump the leak occurs. The square seal is in the forum with photos)
Tip 2; two shafts in the pump need to be aligned, the pin holding the pulley in place on the outside, and the four roller shaft inside the pump with fiddly roller bits (tip; rubber band these to hold in place) has a mark.
I jagged it in previous seal replacements but Adrian shows it... 2.11min mark shows the square seal area, it doesn't have the black cover
https://www.youtube.com/watch?v=Q4c99eO ... L&index=26I have two pumps not working now, that were with leaks, one I resealed and wouldn't go, the spare did, but leaked from front shaft later and created the current situation. Both pumps needed the shafts realigned and I thought that's it, and I have a spare, but no go after buying kits here
https://injectionpumps.co.uk/product/lu ... unger-kit/No electronic parts available anymore, and could get a resealed pump with that caveat for $2750AUD, all the parts had ohms resistance but I've been here a few times. I broke a fan shaft going to Adelaide, fixed it but got an engine management light and drove to Alice Springs on limp mode. Resealed the pump in Alice, 1.5hrs out and hot on the road, eng mgt light again, limp mode to Darwin, old and have time but no money, still scary trip with 130kph speed limit and any rise in the road and you slow from 80kph.
The motors are bullet proof, gearbox needs another gear, great to drive. I'm old and have time and no money, rust holes in the corners of the windscreen and front passenger footstep plus the roof. So while waiting for parts, I used a colorbond gutter sheet steel and riveted closed all holes with silicon. I had been thinking about these issues for a while, body filling would crack with the rust, so the motor and running gear are good, the holes are fixed, I have lived in it for 8yrs since a divorce, 65yo, I think the van will outlast me.
I would love a Transit Trail and may get one, AWD would be handy traveling, 8 or 10sp auto gearbox, ton of power. But I'm saving the planet using the VG till no more, and there's the money and I'm quite comfortable in it. I shear sheep, so drive to the farm Sunday arvo and camp till Friday afternoon, so it's perfect for me and a workhorse of a vehicle for it's age.
So going manual, the Bosch isn't a new pump, but resealed conversion for a VG Transit.
https://cdsa.net.au/product/ford-transi ... onversion/
