benno123 wrote:all of a sudden my lovely campervan stopped starting. When i turn the ignition key i hear a click but no starter motor engages. Battery is full and in order. I do see my brakelight from the handbrake comes up when i try to start, never noticed this before.
It ran great until 2 weeks ago. Then it sat on the driveway. As a APK (dutch MOT) is coming up i wanted to make a nice spin today but nothing happened.
am i correct there is no start inhibitor on these busses and the factual key is merely a switch under the ignition barrel ? I would like to get it up and running asap
My campervan is a Ford MK5 2.5 DI from 2000.
greetings,
Benno van Ham
benno123 wrote:PATS code 32 gets delivered, that seems to come from the Fuel pump solenoid. I can see that under my bonnet already some previous owner has started tampering with wires just to make it any easier.
I can not find a third fusebox. Mine has one big one under the Steering wheel (LHD) all fuses work.
One small one next to the starter battery on the right front wing with 3 fuses in it all ok.
There should, could be a third box according to what i read in fora, this would be locates on top of the chassis. One side is a airbox lH and on the other one is an ABS control box.
This is freaking me out, i cannot find anything on this issue online that looks like my own problem.
Any help would be dearly appreciated.
greetings,
Benno
benno123 wrote:Yes, there is a module on it, doesn't look like it can be easily dismantled however (propably a good option for a anti theft device).
benno123 wrote:Well it doesn't turn over basically. Two days ago i had 1 time i coul get it to get the PATS deactivated and it started on the first turn. This only worked once. After that nothing. PATS stays active, throws code 3-2
I have checked the fuses in the car fusebox 32 and 33 seem ok.
I was hoping to find the mystery third box under the bonnet somewhere but on the images i have seen on the web are all from RHD cars and there it sits on the chassis rail under the steering. In my case there is the ABS pump.
This weekend i will put some extra time in it, as it is a simple 2.5 DI maybe bypassing the PATS and running live wire to solenoid and the starter wire from ignition to starter solenoid will solve the trick for me. Will try this.
I have a ForScan and adapter on the post to me, hopefully that can be of use for me also. Thanks all for thinking with me and providing me with valuable information on this frankenbaby.
greetings,
benno
