According to the code that is the issue but how to get around it. At the moment it is a dead beast on the driveway.
I don't have any checkenginelights with igntion on.
Only if i try to start the handbrake light comes on and nothing more happens but with PATS active that is to be expected.
My Forscan adapter arrived but it can not connect to the car. The adapter is found, when it trys to connect i only see a can error #9. Can you access a 1996-1998 MK5 Transit with forscan or is it just too old ?
I have not tried putting power on solenoid and bumping the starter. But i guess that will the next trick to see if it will run.-
Benno
