2.5 Di Turbo - Wont turn over * updated * ITS FIXED !!!!!!!
Re: 2.5 Di Turbo - Wont turn over
Postby V184 » Tue Feb 26, 2008 3:46 pm
Starter relay ? which on the earlier model is under the bonnet ?
V184
Postby Plug_ » Tue Feb 26, 2008 4:58 pm
V184 wrote:Starter relay ? which on the earlier model is under the bonnet ?
Any idea where under the bonnet ?
Plug_
Postby mick63 » Tue Feb 26, 2008 5:32 pm
on the MK5 transit it is below the battery bolted to the inner wing ,it's a black box with a multi plug going to it , cheers Mick.
mick63
Postby Luke » Tue Feb 26, 2008 6:06 pm
if its the starter relay -with the ign on and a spanner shorting out the starter it would start wouldn't it :? :?:
Postby Plug_ » Tue Feb 26, 2008 6:40 pm
Ok I got more info..... I've pulled the pats box and the yellow relay (starter inhibitor ?)
If I short the pins of the yellow relay with a piece of wire with spade terminals, the starter will spin up on the key :D
So I'm more convinced that the pats is shagged
I now need to know what colour wire is the feed to the rim from the pats box :?
The wiring diagrams in the haynes manual are extremely unhelpful :evil:
Plug_
Postby Guy88 » Tue Feb 26, 2008 6:44 pm
Plug_ yopu dont have a RIM module
The PATS cannot be bypassed on a TD, the ECU has to recieve a varyable voltage from the PATS
On a MK5 the starter relay is under the dash (yellow one next to the pats) MK4 is on the inner wing
Do you have the engine light come on then go out after
On my non turbo the pats LED comes on for 3 secs then off, i think the early TD is the same
Only thing you could do to rule out the PATS is get the module and transponder from another van then have the ECU coded to it
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby V184 » Tue Feb 26, 2008 6:46 pm
check the small earth cable from the battery is ok, think if its disconnected/broken the engine man light dont come on but engine spins over ? have you tried giving it a sniff of easy start ?
V184
Postby Plug_ » Tue Feb 26, 2008 7:06 pm
Ok almost time to call it quits...... is there anybody I can call out to fix it ?
Tried the local auto locksmith, described the symptoms.... didnt want to take it on
Tried the local auto electrician, didnt want to take it on....said call auto locksmith
Tried main dealer...said they can book it in for a couple of weeks time :cry:
I'm just outside Reading and I'm happy to pay someone who knows what they're doing
Plug_
Postby Guy88 » Tue Feb 26, 2008 7:18 pm
I havent got any code reading gear but im happy to come and look see if your desperate
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Plug_ » Tue Feb 26, 2008 7:33 pm
Guy88 wrote:I havent got any code reading gear but im happy to come and look see if your desperate
Do you think its likely to be fixable without code reading gear :?
Plug_
Postby Guy88 » Tue Feb 26, 2008 7:53 pm
Dont know TBH :roll:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Plug_ » Tue Feb 26, 2008 8:01 pm
Guy88 wrote:Dont know TBH :roll:
Thanks for the offer....... but wouldnt want to waste your time
I'll call the ford dealer and get a price on a pats unit....if it aint too crazy I'll order one and try it
Plug_
Postby Guy88 » Tue Feb 26, 2008 8:18 pm
Getting it coded will be the expensive bit
Offers there if you need it
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby AndyG » Tue Feb 26, 2008 9:08 pm
Plug_ wrote:- plus the pats lights just stops flashing - it doesnt come on solidly
Sorry, but you aren't explaining yourself very clearly :!:
The PATS light should come on for a few seconds and go off (with ign. on)
So is it flashing :?:
Have you got other keys with the one you are trying to start it with :?:
Does your key look like a proper Ford one with the chip in it :?:
Have you got a spare key :?:
Postby Plug_ » Tue Feb 26, 2008 9:57 pm
pats light flashes normally when ignition is off
when you switch the ignition on the pats light stops flashing straight away
Have two normal keys and one red key...tried all three
Plug_
