dieseldel wrote:hi
when you turn key listen for a click from the starter motor solenoid , if it does click but engine does'nt turn over, then starter is u/s, if it doesnt click run a wire straight from battery positive and touch on smaller of the two starter motor wires, if starter spins engine over, check relay ( either piggy backed onto battery tray or in fuse box panel)
Plug_ wrote:The PATs led doesnt flash any code, as soon as I switch on the ognition it just switches off.
Guy88 wrote:Sounds like a PATS problem. Does the LED light up at all
Check fuses 32 and 33
Is there a clicking from under the passenger side of the dash
Guy88 wrote:With the key in run, if you engague the starter manually does it still not go
Andyg wrote:When you turn the ignition on, tell us EXACTLY what lights are coming on and for how long
You should have "engine" "ign" "bat" and your "PATS" light coming on and then the "PATS" light going off after a few seconds
gemini wrote:i think its the rim module on the solenoid
