blue smoke
blue smoke
Postby colly 695 » Sun Apr 19, 2009 9:00 pm
Hi all,i have a 96 100l lwb shr smily transit,when i start it cold,it chuffs out a bit of blue smoke,but quickly stops after running for a few seconds.
The engine im told is sound,there's no signs of oil seeping out anywhere,can anybody tell me what is causing this blue smoke at start up,and is it anything to worry about?
cheers Davie
A life without a transit aint worth living
96 mk5 lwb/semi hi roof
90 mk3 pinto tipper
colly 695
Re: blue smoke
Postby Steve B » Sun Apr 19, 2009 9:20 pm
blue smoke generally is not good, usually a sign of the motor burning oil, possibly piston rings or just a worn engine, how many miles do you have on the clock?
Steve B
Re: blue smoke
Postby colly 695 » Sun Apr 19, 2009 9:24 pm
hi, its got 103,000 on the clock,just been serviced aswell
Davie
90 mk3 pinto tipper
colly 695
Re: blue smoke
Postby Steve B » Sun Apr 19, 2009 9:27 pm
can you tell if the engine oil level stays the same over a period or do you have to top it up
Steve B
Re: blue smoke
Postby colly 695 » Sun Apr 19, 2009 9:33 pm
oddly enough,it was low at one time,the garage topped it up,im sure this was before the service,(2 or 3 months ago) i have checked it recentlly,and it is between min and max,will check again tommorow
90 mk3 pinto tipper
colly 695
Re: blue smoke
Postby MinorMatt » Sun Apr 19, 2009 9:35 pm
You sure its blue and not white??
White smoke at start up is fairly common and nothing to worry about
96 N 120 Turbo'd DI SWB Low
97 P 150 76PS Di SWB low ex essex police
Lucas laser 2000 & IDS onwner
Re: blue smoke
Postby Steve B » Sun Apr 19, 2009 9:38 pm
keep an eye on the oil level, try and get a sniff of the smoke on start up, you should be able smell it if its burning oil
Steve B
Re: blue smoke
Postby colly 695 » Sun Apr 19, 2009 9:39 pm
yeah deffenatly blue,only a puff thats it not a big cloud lol
90 mk3 pinto tipper
colly 695
Re: blue smoke
Postby scoobysti » Sun Apr 19, 2009 9:41 pm
valve stem oil seals ???
scoobysti
Re: blue smoke
Postby Steve B » Sun Apr 19, 2009 9:42 pm
if its only on start up then I`d be inclined to go with scooby on this one
Steve B
Re: blue smoke
Postby colly 695 » Sun Apr 19, 2009 9:46 pm
cheers fellas,as isay its just at startup,when normal driving,theres nothing i can see coming out at the back,even going up hills with foot to the floor no smoke blowing out,il mention about these seals to the garage.
Cheers Davie
90 mk3 pinto tipper
colly 695
Re: blue smoke
Postby Steve B » Sun Apr 19, 2009 9:49 pm
let us know the result
Steve B
Re: blue smoke
Postby colly 695 » Mon Apr 20, 2009 6:39 pm
Hi all, could have found the problem,oil level is low,so il top up again and see how it goes must of used alot of oil recently,and the only time you see smoke is at startup,so must be burning somewhere
i am going to look into the stem seals anyway,
keep you posted
Davie
90 mk3 pinto tipper
colly 695
Re: blue smoke
Postby maciejd » Mon Apr 20, 2009 7:16 pm
What about smell of fumes ? Is it very strong "diesel" and the "blue" colour is clear blue or rather the smell is like burning oil and its blue-gray ?
If the smoke disappear after few seconds it might be about too small dose of fuel and too much air... Are fuel lines OK ? Maybe they catch some air during the start... If this will be about burning oil - in my opinion - the smoke will gone when the engine get wormer (but then it will be not about few seconds - rather few miles) or you will see smoke all the time, depends on the engine condition.
regards, Maciej
It's not about driving a van. It's about Ford Transit.
1996 FT Van, 525 000 km - restoration / progress report topic
2004 FT Euroline, 150 000 km - progress report topic
2008 Renault Clio, 40 000 km
2011 Renault Laguna, 90 000 km
maciejd
Re: blue smoke
Postby colly 695 » Mon Apr 20, 2009 8:52 pm
just started it again,been sitting for 3 hours,no smoke at all,seems to be only when sitting all day or night,the colour is definetly blue,allbeit see through light blue,the fumes are strong at first come to mention it,does smell rather much like diesel.
Another idea ive had it to get the injectors reconditioned did this on an escort van last year for £100.maybe worth a try
90 mk3 pinto tipper
colly 695
