blue smoke
Re: blue smoke
Postby Steve B » Mon Apr 20, 2009 8:59 pm
Tis looking much like valve stem oil seals now :wink:
Steve B
Re: blue smoke
Postby alanwh » Tue Apr 21, 2009 8:48 am
Do a long idle, 5/10 mins while hot then blip the throttle, any blue smoke is valve stem seals.What oil have you got in ?
Blue tinged white smoke on start that gets better the warmer the mornings get is a timing cold start issue.
alanwh
Re: blue smoke
Postby colly 695 » Sat Apr 25, 2009 1:15 pm
Hi all, checked the oil the other day,and the dipstick was DRY :shock: ,topped it up took nearly 2 litres to bring level to inbetween min and max.
The oil light never came on while driving, thought it would of if it was that low,it does work as it lights up when switching on,the oil in it is shell diesel plus 10-40w. This past couple of days,the smoke in the morning when starting is whiteish with a bit of blue mixed in,,when it starts it idles roughly and after a couple of revs its fine.
Il check the oil again in a couple of days as i say,and if the level is low again,then must be the valve stem valves as steve b and scooby suggested,my garage can't do it at the moment,is it a hard job to do,or can an amatuer like me manage it?
A life without a transit aint worth living
96 mk5 lwb/semi hi roof
90 mk3 pinto tipper
colly 695
Re: blue smoke
Postby mikmik » Wed Apr 29, 2009 8:51 am
Any update on this colly?
mikmik
Re: blue smoke
Postby colly 695 » Sat May 02, 2009 12:13 am
Hi all just an update on this blue smoke,topped the oil up last week,and level is still the same a week on.
I've noticed its every other start-up the blue is coming out,every other time its sort of white strange :?
I'm still gonna get these valve stem seals checked though
Let you know if theres any change
90 mk3 pinto tipper
colly 695
Re: blue smoke
Postby Altransit » Sat May 02, 2009 12:16 am
When was the timing belt last changed?
Re: blue smoke
Postby colly 695 » Sat May 02, 2009 12:28 am
i know it had the cam belt changed about 15000 miles ago,the fan belt was changed a couple of months ago in the service,but the timing belt i have no idea,this is'nt the cam belt is it :?: ,sorry, but what i know about engines you could fit on the back of a stamp :lol: at least im honest :lol:
There was no mention about the timing belt in the service though,only bought the van last september
I'l go to the garage 2morow and ask them to check the timing belt,and see what happens-never given this a thought.
90 mk3 pinto tipper
colly 695
Re: blue smoke
Postby Steve B » Sat May 02, 2009 12:41 am
The cam belt, or timing belt are the same thing, it might have jumped a tooth, check it out just in case
Steve B
