Done some shots of the engine bay, the dials, and the van itself, ive photos what I think is the stop solenoid. is that it?
coresaint wrote:Problem.
Stop solenoid is inside that fuel pump, can't get it off, and too much hassle.![]()
Also it's got an immobalizer fitted, and the key is almost worn out, course we don't have the red master key, to reprogram it.
So is there any way to bypass the PATS? and to swap this ruddy fuel pump for something elsesay a bosch
If there is, I'd be greatful if someone can do it ASAP, since the curren't solenoid triggers off the engine light and therefore triggers limp mode, i can stop n start and the light goes out but its only after a short while before another start causes it to come on again. It's a working van and its needed to goto work effectively
coresaint wrote:don't care about liabilities! if it goes wrong it goes wrong, not going to hold you responsible, fact is it is broke and needs fixing so..![]()
how much you want for it?
i'll happily look for a bosch pump no problem. is there a good pic diagram? (will look in the info section). then i'll go grab one.
So black key does programming!?
will try it!
