How to remove transit ignition barrel
Postby rob_887 » Sat Jul 04, 2009 6:52 pm
On a 1996 Mk5 Transit
Need the keycutting but the key is so damaged its got no numbers and i've been told its on the barrel as well
rob_887
Re: How to remove transit ignition barrel
Postby bez » Sat Jul 04, 2009 7:17 pm
post a pick of the key and ill tell you the code
:wink:
if in doubt flat out!
bez
Cosworth Powered
Cosworth Powered
Postby rob_887 » Sat Jul 04, 2009 7:25 pm
bez wrote:post a pick of the key and ill tell you the code
:wink:
Does it matter that the key does not have the plastic bit on it no more?
Just a bit of metal.
rob_887
Postby bez » Sat Jul 04, 2009 7:30 pm
nope just need a close up of the side of the key(point end)
bez
Cosworth Powered
Cosworth Powered
Postby rob_887 » Sat Jul 04, 2009 10:09 pm
I cant take any in enough detail to say any thing other then its made of metal
rob_887
Postby trigger » Sun Jul 05, 2009 11:02 am
What he's saying is if you post a clear pic of the end of the key he can read the bumps in the metal and give you the code from that
Mk5 Transit the daddy
trigger
Postby rob_887 » Sun Jul 05, 2009 6:15 pm
Yer thats what i was thinking buy my camera is so crap its all blurry looks like know bumps
rob_887
Users browsing this forum: blue estate
