madmark_50484 wrote:Kinty
I actually disagree with you the EGR mod would happily help your intake not get coked up I think your "it helps start cold engines" is flawed as the early DI never had egr valve and start fine.
An engine is designed to burn diesel so you need oxygen to do that so what benefit would taking your exhaust gas to that
As for "EGRs work fine" why don't you ask the mk6 & mk7 crew if thats the case
egr on this van as ford intended does help cold start/warm up.ON THIS VAN.egrs on modern vehicles are totally different,the early d.i and yorks didnt have it .....pollution wasnt such an issue then.it was intended to reduce emissions ONLY.now as a bi product it does the above.
NO body said it does or doesnt make a van start. why would i need to ask mk6/7 owners ?????i am talking about this d.i mk5 van specifficaly,allthough fundamentally in theory the same principles apply. unlike other vehicles this d.i egr system is primitive in that its vacuum operated and not metered as such...modern vehicles are...egr s sticking on petrol engines is again different as a sticky one wil cause weak mixture and maybe a non start situation,mil light illuminated.
as for coking up your inlets...hmn ok...your still producing that gunk in your exhaust,whether it goes through egr or not ,i would suggest you have problems in that situation .ive removed egr blanking plates on trannys and blank is never excessively carboned.
as for this remark"An engine is designed to burn diesel so you need oxygen to do that so what benefit would taking your exhaust gas to that
read this whole thread again mate.
