madbri wrote:right i changed my oil 2day! over due as done 10 000 miles warm the enginge up 4 10 mins and droped out no probs but very black chainged oil filter put 15/40 in as free . right this is where id like some feedback? ive read up all about heaters to no sucsess with any think but since changing oil temp alot better heater to fucin hot and no need to state the rest ie enginge so much queiter and less desiel nock but the other think once again read up bout touque sleeve and the erg valve mod because of smoke and i mean sometimes muc off black smoke but then just like that it cleared but now next to no smoke how can al this b down 2 oil change thanks by the way its a 2.5 nanna
birdy wrote:Just backs up what most have agreed over and over again.Diesel 2.5 di needs 10/40 15/40. In uk 5/30 only to be used when temps fall below 10% .Some will try and save face by claiming temp is and has been below 10 deg for a while but in the main uk is normally warmer than 10 deg .
darkbluevanman wrote:Have a look here.... http://www.ratwell.com/technical/OilSelection.html
Under Engine wear: All these oil recommendations from VW are fine except they forget to mention one important detail: they are the recommendations for a NEW engine. As the engine ages, the bearing clearances increase and you need to use a thicker oil to maintain proper oil pressure. What's good for your engine isn't necessarily good for someone else's engine simply because of the difference in mileage and actual wear.
madbri wrote:darkbluevanman carefull u read 1 of my posts and didnt slate it any way now me vans sexy and warm will i get a better mpg or am i dreaming
darkbluevanman wrote:There's no problem with using 5w30? My point is that you can use a host of other oils viscosity wise and compound wise.... it doesn't HAVE TO BE 5w30?... anyway! Is it a Diesel oil your using?
dibs wrote:Called in at my local Ford dealer today to see if they would do a trade price service kit. Yes, was the answer . Great, but....... they could only supply me with an oil filter Not only did they not have any 10w/40 in stock (the recommended oil on their system btw), but they informed me that they can't even get it from the suppliers Useless This is the same dealer in Ashton Under Lyne that quoted me over £15 for a dash bulb!!
