Oil
Re: Oil
Postby mrmurf » Tue Jan 19, 2010 8:11 pm
wot a kerfuffle lol :lol: :lol:
mrmurf
Re: Oil
Postby madmark_50484 » Tue Jan 19, 2010 9:10 pm
Nice to see a split opinion although I dont know for certain I would put 10/40 in now as Im with Birdy on this it make sense and I have heard a very wise mechanic who said the same thing I know what Ford said and you say about the Ford test beds but experience can show otherwise
Past
MK5 98 R reg Transit 190 LWB Semi hi Top
Mk5 98 S reg Transit 190 LWB High Cube
Present
Mk5 96 N Reg Transit Luton
Forum for bus enthusiasts and preservationists
www.busesuk.co.uk
madmark_50484
Re: Oil
Postby MinorMatt » Tue Jan 19, 2010 9:39 pm
Heres the page relating to engine oil in the early mk5 handbook... Notice ford recommed 10/40 :lol:
we especially recommend you use *** SAE 10W40 or *** 5W50
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Re: Oil
Postby MrMPuk » Tue Jan 19, 2010 9:44 pm
Yep, 10w40 mineral and 5w30 semi synthetic.
Re: Oil
Postby MinorMatt » Tue Jan 19, 2010 9:56 pm
doesn't mention 5/30 except on the pic...
Either way, according to this it sounds to me like ford recommend 10/40 over 5/30
93 L GL Minibus
Re: Oil
Postby birdy » Tue Jan 19, 2010 9:59 pm
Give in while your'e losing. :wink: It appears Ford are only really reccomending 5/30 for Siberia/Alaska etc
birdy
Re: Oil
Postby madbri » Tue Jan 19, 2010 10:04 pm
so by that chart 15/40 is good? just been given 2x5 gallons of it. hope i found a use 4 it :wink:
madbri
Re: Oil
Postby MrMPuk » Tue Jan 19, 2010 10:05 pm
It's not a case of losing, that is an old superseded manual. The later manuals and Ford's workshop manuals tell a different story and as you've already said yourself, technology has moved on. :wink:
Re: Oil
Postby birdy » Tue Jan 19, 2010 10:07 pm
Pretty sure the oil i just used on last change was 15/40 semi as reccomended to me by Euro parts and my mechanic.
birdy
Re: Oil
Postby birdy » Tue Jan 19, 2010 10:09 pm
Please post the graph from the later manuals so we can all compare the change in thought by Ford.
birdy
Re: Oil
Postby madbri » Tue Jan 19, 2010 10:18 pm
birdy wrote:Pretty sure the oil i just used on last change was 15/40 semi as reccomended to me by Euro parts and my mechanic.
would u check 4 me? :wink: i take it ure vans ok with it?
madbri
Re: Oil
Postby darkbluevanman » Tue Jan 19, 2010 10:35 pm
Ford would tell you dogshit was best if they thought you were gonna buy it off them....
It's an old diesel design... it will cope with almost anything, BUT... 5w30 (or poss 10w40) FULLY SYNTHETIC offers the best protection, but isn't ness'
darkbluevanman
Re: Oil
Postby winterheating » Tue Jan 19, 2010 11:19 pm
5w-30 semi synthetic will protect in this country for temps you will have.
but mineral oil from new, does not have the properties to resist deteriation, plus cheap oil does not have the addatives required to meet any of fords spec, and is generally not good at low temps.
the ford handbook even says to choose what oil you require for temps.
using a sae40 oil is 30% thicker than a sae30 oil, so what reason would you want to use a higher viscosity oil in your engine that is recommended :?: :?: :?:
age :?: using a higher viscosity engine oil will only cause more problems :roll:
winterheating
Re: Oil
Postby MinorMatt » Wed Jan 20, 2010 10:42 am
The point is that ford recommended 10w/40 if you read the blurb... (or 10w30 if all you are worried about is optimum fuel economy) I wouldnt want to put a thinner oil in!
93 L GL Minibus
Re: Oil
Postby birdy » Wed Jan 20, 2010 1:36 pm
Truth is The Di will be happy with almost any slippery stuff as its blood because it is such a durable engine,
birdy
Users browsing this forum: madmart132
