transitjack wrote:i quite often cut screens out to put in other vehicles
you need some wire
http://www.power-tec.co.uk/
scroll down bottom left
i use the gold stuff in a length of 12 inch and a pair of mole grips each end (and a helper)
for the windscreen sealent you need to go to your local factor i pay $8 for a tube that i warm up in the kettle prior to use
hth
WINDSCREENGUY wrote:yeah mike glue smoo
WINDSCREENGUY wrote:it is possible but not really worth it a new windscreen can be had for £75 to £95 by the time you have bought a second hand windscreen and bought the glue and primers it would probably work out the same
williamraff wrote:Hi folks, can anyone advise whether transplanting a MK5 SWB windscreen from a scrapper is a viable operation or does it have to be a supply and fit from a specialist If this is the case can anyone recommend a good (cheap) fitter?
Chers,Will
