by Backbone of Britain » Wed Jun 09, 2010 7:22 pm
According to Ford Etis Cam belt is every 60,000 or 5 years
Service Schedule
Model Transit 1995
Variant DIESEL/MANUAL (08/1994 - 07/1998)
VIN SFALXXBDVLTL10674
Interval 4 Years (40000 ml)
Repair/Order No
Reg. No.
Reg. Date
Radio Code
Mileage ml
Outstanding Field Service Actions. Please ensure they are completed.
No Campaign Message(s) found
Driving Vehicle into Workshop
Instrument gauges, warning/control lights and horn Check operation
Clutch Check operation/adjust, if necessary
Washers, wipers Check operation/adjust, if necessary
Inside Vehicle
Exterior and respective control lights; instrument cluster illumination Check operation/condition
Handbrake Check operation/adjust, if necessary
Seat belts, buckles and stalks Check operation/condition
Outside Vehicle
Door check straps Check operation/grease (steel check straps only)
Slide door Check operation
Hood latch/safety catch & hinges Check operation/grease
Under Hood
Engine compartment lamp Check operation - if applicable
Wiring, pipes, hoses, oil and fuel feed lines Check for routing, damage, chafing and leaks
Engine, vacuum pump, heater and radiator Check for damage and leaks
Auxiliary drive belts Check condition, adjust tension if necessary
Coolant Check anti-freeze concentration: °C
Coolant expansion tank, power steering fluid, washer reservoirs and battery Check/top up fluid levels as necessary - in case of abnormal fluid loss, a separate order is required to investigate and rectify
Battery terminals Clean, if necessary/grease
Valve clearances Check/adjust
Under Vehicle
Engine Drain oil and renew oil filter. Renew sump plug gasket where fitted
Steering, suspension linkages, ball joints, sideshaft joints, gaiters, propshaft 'Guibo' joint Check for damage, wear, security and rubber deterioration
Engine, transmission, rear axle, transfer box Check for damage and leaks
Pipes, hoses, wiring, oil and fuel feed lines, exhaust Check for routing, damage, chafing and leaks
Underbody Check condition of PVC coating
Tyres Check wear and condition, especially at tyre wall, note tread depth RF mm, LF mm, LR mm, RR mm
Rear suspension 'U' bolts Tighten to correct torque
Brake system Disc brakes: With wheels off, check brake pads and discs for wear. Check rear brake linings for wear (using drum brake inspection hole). (More often under severe duty conditions)
Outside Vehicle
Engine Refill engine oil
Brake fluid Check level - in the case of abnormal fluid loss only, a separate order is required to investigate and rectify
Tyres Adjust pressure
Spare wheel Adjust pressure, check wear - condition (note tread depth) mm
Rear load space lights Check operation
Wheel nuts Tighten to correct torque and check for correct type. Check for rim damage
Ball joints Check ball joints for wear, refer to TSB 129/95
Service reminder sticker Affix to driver side B pillar
Extended Period Maintenance
Brake system Every 2 years - Renew - brake fluid (LTS 12 154 4)
Air conditioning Every 3 years - Check temperature at the evaporator outlet tube. Check air conditioning lines for damage and leaks (LTS 34 619 1) (TSB 67/2002)
Cooling system Every 4 years - Check/clean pressure cap, renew if there is seal deterioration
Cooling system Every 6 years - Blue/green coloured coolant. Drain, flush and refill with purple Super Plus(LTS 24 122 4)
Cooling system Every 10 years - Orange/pink coloured coolant. Drain, flush and refill with purple Super Plus (LTS 24 122 4)
Cooling system Every 10 years - Drain, flush and refill with purple Super Plus(LTS 24 122 4)
Camshaft drive belt, tensioner and idlers Every 60 000 miles/5 years - Renew - 2.5 Diesel (non Turbo)
Camshaft drive belt Every 60 000 miles/5 years - Renew - 2.5 Turbo Diesel
Back
©Copyright, Ford Motor Company 1994 - 2010 | Privacy Policy
2006 Mk6 115 T350 LWB Highroof
2008 Mk7 115 T350 LX LWB Highroof
