Luke wrote:black one looks mint
vanfox wrote:I take it you will all tell your insurance company about these non standard modifications...........?
It's not as if you can hide different wheels under the bonnet!
Luke wrote:darkbluevanman wrote:good point, but we're fabbers not engineers, rings and welding are free, drilling the wheels isn't .... are those landy wheels in the piccy?? the pcd looks quite outward on the flange (if you know what I mean?)
ive got a jig to redrill the wheels - bolts up to the landy pcd and you just drill through 3mm holes which are 160pcd
i'd do em you but you could almost make a jig on the lazer - 5x165 holes 12mm and 5x160 3mm's then bolt it up with some old studs drill through the 3 mm with a pistol drill then go through a set of drills untill you get to the 13mm then all you need is a 60deg taper bit to put the nut seat on - piece of piss really
then weld the old holes up
