Hastings wrote:Hi Where is the resistor situated & what does it look like, searched for it under the dash can't see it.
Cheers
Gary
demographic wrote:Hastings wrote:Hi Where is the resistor situated & what does it look like, searched for it under the dash can't see it.
Cheers
Gary
The resister is usually somewhere behind the front light on the drivers side and is a coil of metal wound round a ceramic pot if I remember right.
sideshow_bill wrote:Usualy if the resistor has blown, the fan only works on full speed = resistor bypassed
MrMPuk wrote:Most probably the resistor has gone so the fan only worked on speed 3 then the wiring on the back of the switch has melted.
viewtopic.php?f=31&t=12288
Hastings wrote:if it is the resistor it would still work on setting 3, it's not working on any stetting. I might try changing the switch for the settings.
