Aardvark wrote:Thinking about Robbie's suggestion........................................
If I was designing a pump I would incorporate some sort of pressure bypass valve to prevent excess pressure blowing the seals out. Like if you were spinning the pump abnormally fast by redlining a petrol engine due to a stuck throttle.
So, by putting a larger pulley on the steering pump you might be asking for trouble.
Discuss.
If I was designing said pump I'd make it give adequate flow at way below normal idle (say, 500 rpm) and have a max design spec of, say 10,000 rpm (way past what a normal engine would rev).
