blocking off pipe
blocking off pipe
Postby CH1 » Wed Nov 24, 2010 10:45 pm
some one told me the other day to block off this pipe off, what will I benefit from doing this :?: cheers
M1 Tyres
Mobile Tyre Fitting Service
Covering the North East
http://www.m1-tyres.co.uk
Currently running:
Mk5 swb 80 with twin SLDs
Mk7 110ps T300 fwd pickup
Mk7 125ps T350 lwb Euro5
CH1
Re: blocking off pipe
Postby Grenadekid » Wed Nov 24, 2010 10:53 pm
Not sure about the mk5 m8 but does make a difference on later transits but if you wait a little some of the mk5 experts will tell you exactly :D
At home
05 220 tdci connect (remapped to 115)
94 toyota rav4 2.0 petrol
2011 kia sportage kx3 2.0 diesel
2001 RAV4 NG
Grenadekid
Postby G40GES » Wed Nov 24, 2010 11:16 pm
DONT DO IT!! :!: your eyes will explode and your ears will go pop
Gadge in the shed... STILLfreezing me bits off...
G40GES
Postby dyte2004 » Wed Nov 24, 2010 11:20 pm
its a egr feed pipe it will stop your engine breathing its on fart gas
dyte2004
Postby CH1 » Wed Nov 24, 2010 11:32 pm
so should i leave it alone
M1 Tyres
Currently running:
CH1
Postby dyte2004 » Thu Nov 25, 2010 12:09 am
CH1 wrote:so should i leave it alone
a lot of poeple blank it off do a search on egr blanking removal theres lots of good right ups on it
dyte2004
Postby trigger » Thu Nov 25, 2010 1:19 am
Do it together with the fuel pump mod it will make your transit go better :D
Mk5 Transit the daddy
trigger
Postby valeterjack » Thu Nov 25, 2010 8:52 am
do the egr mod it makes a difference :twisted: :twisted: :twisted:
Imagemk5 nothing even comes close
www.scottish-vanners.co.uk
valeterjack
Postby M.Badger » Thu Nov 25, 2010 12:29 pm
Disabling the EGR on mine made a heck of a difference to the way it drove. Hills which previously were 'flat stick in a low gear' could now be taken with less throttle in a higher gear. Made it much more pleasant to drive. Reduced the smoke from the tailpipe too. Whether this is down to plain old fashioned not having to cane it everywhere, or because the engine is no longer objecting to breathing its own farts, or some combination of both, I know not for certain.
Do it. What have you got to lose?. If you don't like it, you can always put things back as they were.
M.Badger
