robbie.cee wrote:yeah bridge the switch wires first, if they wrk switch fooked, if not run new wire up right side of a post, along with the others th the light clusters.
damn pg9s(?)
mattster87 wrote:Cheers for help so far, I bridged the wires on the switch and still had no brake lights - does this mean switch is good? I stripped the switch down and cleaned it all up - it blew the fuse when i re attached it but it is not blowing fuses every time i engage switch. I've followed the loom and there is no damage to any wires anywhere, I have Purple and Purple/Yellow coming of the switch, then it joins the main loom. Im guessing purple is the control switch?
I understand bypassing the switch is an effective method although as said finding the cause would be best - but if i cant see any visable damage on the wires could there still be a fault with the wires or is it going to be shorting somewhere else?
Cheers
Matt
sideshow_bill wrote:If you run a new wire, it is best to replace all the wires in the damaged section, as it is unlikely that only one is damaged. It will only be a matter of time before you loose side lights, indicators etc.
