Engine number location
Postby DarkLegend » Mon Oct 23, 2006 11:05 pm
Appologies if this topic has been done to death, had a search and didn't return anything conclusive.
Just wondering where to find the engine number on a 2.5d.
Van is an '87, but i'm not discounting that it may well have been swapped out for a newer model at some stage, so if it changed during the production i'd like to know anywhere it may be located!
DarkLegend
Postby comet » Mon Oct 23, 2006 11:09 pm
have a look on the sump flange below the manifold.clean it with wire wool, just in front of engine mount.
1971 LANDLINER - 2.5DI FITTED NEW BY FORDS IN 2000 - IF YOU WANT A COVER UP ASK THE POLICE THEY ARE THE BEST
comet
Postby gemini » Mon Oct 23, 2006 11:12 pm
gemini
Postby DarkLegend » Mon Oct 23, 2006 11:17 pm
Excellent! Thank you!
I'll have a look tomorrow and make sure it matches up with my V5!
DarkLegend
Postby gemini » Mon Oct 23, 2006 11:25 pm
DarkLegend wrote:Excellent! Thank you!
if it doesnt keep it to yourself, there are plenty of Di's with no number on :shock:
gemini
Postby comet » Mon Oct 23, 2006 11:29 pm
gemini,, my engine number n7-45414, does it mean anythin to you,
comet
Postby gemini » Mon Oct 23, 2006 11:48 pm
no sorry, mrmpuk might be able to help you
gemini
Postby MrMPuk » Mon Oct 23, 2006 11:52 pm
45414 will be your VIN number, what engine is it?
Postby sportscott » Tue Oct 24, 2006 5:46 pm
On a Dutch reg document the engine number is'nt listed or the colour of the vehicle, I suppose they feel it's not necessary.
Transit the everyday mans van....
sportscott
Postby FredTransit » Wed Oct 25, 2006 12:10 pm
sportscott wrote:On a Dutch reg document the engine number is'nt listed or the colour of the vehicle, I suppose they feel it's not necessary.
:shock: Not secessary??
FredTransit
Mk2 Trannyist
Re: Engine number location
Postby Bill Bourke Special » Sat Aug 12, 2017 5:18 am
AAARRRGH ! The post isn't done to death if you STILL cant find the engine number. lol. Here is where i found mine.....on the side of the sump lip, driver side, toward the rear of the engine, well right at the bell housing, obscured by engine bracket. Found it using a telescopic camera!!. If you slide your left hand along the side of the block where it meets the sump, all the way back, between the engine mount and the block, extend your middle finger until it hits the bell housing. Your finger is now on a machined flat with the number on it. use emery, spray and rag. If you have someone plant their face in next to the brake booster, with a torch they will see your finger. Good luck
Bill Bourke Special
