Tip: removing viscocoupling+fan
Postby taneven » Thu Oct 26, 2006 6:35 pm
Hello all,
I heart that it could be a problem to remove the visco-coupling with fan before changing the timing belt. As a result I didn't remove the fan before changing the timing belt, and it proved to be a challenge to exchange the timing belt in this situation.
Since I wanted to know what my visco coupling was like (there is a play of a few mils in the axial direction) I used the following trick to loosen the viscocoupling nut. As you mat know it has a righthand tread, so loosening has to be done against the clock direction.
- Put a 10 mm flat ringspanner on one of the fandrivepully bolts, making sure it is in roughly a 2 o'clock position.
- turn the engine anti clockwise by hand until the spanner runs against the crankshaft pully. The fandrive pully is now mechanically locked
- us a (adjustable) spanner to loosen the viscocouplingnut. As the fanpully is locked as the backside of the ringspanner is now tight against the nut, there is no torq force left on the fandrivepullyfixingbolt (I like the word!) self and as a result the viscocouplingnut can be loosened with a considerable torq. No slamming, just unscrewing. Mine was the first time in 3 years to be loosened and it seems the material is inoxidable.
If only I had known this in advance, I would have removed the fan before changing the timing belt. This worked fine for me, it may be a tip for you!
Taco
owning a 85 HP 2.5 liter double cabined 1999 mark 5 Turbodiesel and still liking it!
taneven
Postby sportscott » Thu Oct 26, 2006 6:57 pm
fandrivepullyfixingbolt (I like the word!) helaas het is vijf woorden verkeerd geschreven, zonder spatie maar klinkt mooi :wink:
Transit the everyday mans van....
sportscott
Dutch
Postby Terry » Thu Oct 26, 2006 7:12 pm
My Dutch is pretty rusty but I reckon it says......
Unfortunately it is 5 words written wrongly, without spaces but it sounds beautiful.
Pallet Puller
Terry
Postby MrMPuk » Thu Oct 26, 2006 7:15 pm
fan drive pully fixing bolt, I think it should be more like this!
Postby rover » Thu Oct 26, 2006 7:37 pm
Whatever you wanna call it thats the way I've done em for years :D
Rover.
rover
Postby sportscott » Thu Oct 26, 2006 7:48 pm
Spot on Rover!! only joking with Taneven, credit where credits due, not badly written at all for a non native english speaker. After all the dutch do believe they have one of the MOST difficult languages in the world, which is absolute crap, in fact it's very simple and regular grammatically. It's only difficult not to spit all over the person your talking to.
sportscott
Shaking things up
Postby taneven » Thu Oct 26, 2006 8:58 pm
I already thought this word would shake things up a little, that's why I wrote it in the first place. The funny thing is that the reactions are not about the content but concentrated on one word.... :?
taneven
Postby UK_ANDY » Thu Oct 26, 2006 10:35 pm
Love it :!: would like to see the confusion on the dimwits face at our local ford parts counter if I asked for a ''fandrivepullyfixingbolt'' :lol: :lol: :lol: :lol:
old ford's never die they just go faster
Click here to vote for the forum in the Ford top 50 sites!!
UK_ANDY
Postby sportscott » Thu Oct 26, 2006 10:35 pm
It's no revalation you've made about getting the viscous fan off, any way it's not about one word but five put together, it's englishnotdutch. I love that word. One thing you need to know about Brits, we are all Kidneys (we all take the p*ss) nothing personal. Contact the adminstrator and get him to put it in the How to section :P
sportscott
Postby UK_ANDY » Thu Oct 26, 2006 10:37 pm
Good tip mate :D
UK_ANDY
Postby popuptoaster » Fri Oct 27, 2006 9:05 am
i've got a proper viscous fan spanner, bought it about 20 years ago from an autojumble for 50p and its still doing fine. :D
gets used on every car i buy that has a viscous fan as the first job i always do is take it off and throw it in the bin and fit an electric one.
i always use a lock spanner on a pulley bolts, have snapped a couple off though so be warned if your fandrivepulleyfixingbolt is exceptionally tight.
popuptoaster
Postby Torquemada » Sun Oct 29, 2006 10:35 pm
Ooo!
Post us up a pic of that spannery type item please Mr Popuptoaster sir.
Then I could make a copy. :D
But I'll also try the 10mm spanner solution too as soon as I can get back to the old broken down wagon.
Torquemada
Postby MrMPuk » Sun Oct 29, 2006 10:40 pm
This is a viscous fan spanner, basically just a very thin 32mm spanner.
Postby gemini » Sun Oct 29, 2006 11:07 pm
MrMPuk wrote:This is a viscous fan spanner, basically just a very thin 32mm spanner.
and the right shape of course :wink:
gemini
Postby MrMPuk » Sun Oct 29, 2006 11:18 pm
Right shape? Does it need to be a different shape then? I've always managed to get a normal spanner on it ok.
