MK 6/7) turning off the service light?
Re: MK 6/7) turning off the service light?
Postby loot » Sat Feb 06, 2016 11:33 am
You press the brake and accelerator down hard, turn the ignition to pos2 and wait till the light flashes (high spec clocks say resetting)
loot
Postby rogerw » Wed Feb 17, 2016 1:08 pm
Doesn't work one mine cos it's a petrol .
rogerw
Postby loot » Wed Feb 17, 2016 5:10 pm
Out of interest, what's the difference? Ok mileage intervals maybe but the procedure would be the same surely?
loot
Postby Cheese Monkey » Tue Sep 27, 2016 2:27 pm
What triggers the service light to come on? A set mileage since it was last reset? Mine has only done 3-4K since last service at Ford
Cheese Monkey
Postby ake » Thu Sep 29, 2016 6:02 pm
Cheese Monkey wrote:What triggers the service light to come on? A set mileage since it was last reset? Mine has only done 3-4K since last service at Ford
It's a mileage counter, unless it's a 140 or 200 with oil sensor
2 x 18 Custom 270 Trend
2 x 67 Custom 270 Trend
3 x 66 Custom 270 Trend
1 x 65 Custom 290 Limited
7 x 12 Transit 260 Trend
1 x 60 Transit 350
Or is it something worse?
Postby Cheese Monkey » Thu Sep 29, 2016 9:31 pm
Is a 2011 350 140, do they all have oil sensors? Hasnt come back on since I reset it
Cheese Monkey
Postby Cheese Monkey » Fri Sep 30, 2016 9:21 am
Been fine over last few days. I'm guessing the service light came on due to mileage, not oil quality? I would guess it does both?
Cheese Monkey
