MK 7) Fuse Details Fuse Box Location
Re: MK 7) Fuse Details Fuse Box Location
Postby fastwestie » Thu Jan 12, 2017 7:03 pm
Hi
I'm looking for the trailer tow module fuse (83) which is supposed to be in the passenger foot well. Just spent 1 hour looking there but could not find it.
Anyone have any idea?
fastwestie
Postby fastwestie » Fri Feb 17, 2017 6:32 pm
To answer my own question, the fuse is with the trailer tow module at the rear of the passenger step under the plastic cover
fastwestie
Mk7 Battery Fuse Box
Postby v8dave » Wed Dec 27, 2017 1:30 pm
Mk 7 battery or pre-fuse box.
Details from the ford owners handbook.
It lives in the rear of the drivers seat support behind the battery.
Note: this is the dual battery version with the large battery isolator relay. Single battery versions have a solid link in it's place. Access requires you to remove the battery restraint frame.
v8dave
Postby 2e1bts » Thu Aug 09, 2018 4:36 pm
Hi all,
Thanks firstly for great info, would never i a million years located the sneaky fusebox.
Problem i currently have is twofold, firstly radio stopped working. i did fit new after market one, have fitted original back also now not working
checked voltages on red and yellow, have ignition power 12.1v but no perm 12v.
removed new adapter loom and confirmed same on the master loom plug.
Used your info regarding fuses checked both have continuity not just visual check.
2nd part of the puzzle is the reversing sensors now don't work, coincidence i don't think so not been able to locate the control box as yet. i have a mountain of extra relays fuses and boxes in the van (ex gas board / transo one) so have the genny and compressor aux lights heater and all the other gubbins that goes on in the back. this all works at moment so don't think related in anyway.
A look on line seems to show other people having a similar fault to this but no answers given. i have spent the last three night for couple hours each and got no where as yet. totally confused and perplexed as to why this is going on !!!
any ideas gratefully received
Adrian
2e1bts
Postby winny71 » Wed Jul 24, 2019 7:29 pm
Thank you so much
winny71
Postby Bimble » Sat Nov 30, 2019 1:55 pm
Does anyone have the fuse box diagrams as i cant see the original photos due to photobucket changes.
Bimble
Postby Altransit » Sat Nov 30, 2019 2:28 pm
Bimble wrote:Does anyone have the fuse box diagrams as i cant see the original photos due to photobucket changes.
If anyone has the photos or diagrams, I will happily edit them into the original post :)
Postby v8dave » Sun Mar 15, 2020 1:23 pm
images from the drivers manual edition E
[attachment=4]Screenshot_20200315_121425.png[/attachment]
[attachment=3]Screenshot_20200315_121435.png[/attachment]
[attachment=2]Screenshot_20200315_121453.png[/attachment]
[attachment=1]Screenshot_20200315_121519.png[/attachment]
[attachment=0]Screenshot_20200315_121554.png[/attachment]
v8dave
And the six image
[attachment=0]Screenshot_20200315_121631.png[/attachment]
v8dave
Postby Stevecrs » Sat Jun 20, 2020 8:36 pm
I have the same problem. It is on the passenger side behind the drivers seat. lift up the cover and undo the two bolts (#8) on the bracket holding the battery clamp. then undo the (#10) nut in the middle of the battery clamp out of sight and resessed in a groove so that you cannot see it. then disconnect the battery cables. I did not get further than this as my light was failing but I believe the fuse box is there.
Stevecrs
Postby Stevecrs » Thu Jun 25, 2020 4:40 pm
When I posted my last post I had not got to the fuse box. When I got to it it was clear that I was incorrect. It turns out that to find this fuse box one must remove the glove compartment on the passengers side. Then unclip the fuse box that you can see. and roll it forward on the hinges at the bottom of it behind it. Then you will see the correct fuse box. I tested all of these and there appeared to be nothing wrong with the fuses. I went back to the locking of the car and everything worked on the key as it should do. I am not happy that I did not find a bad fuse or some indication of a bad connection. If any one else has had this problem and can tell me how they solved it I will be more than thankful. Mean while I am driving and wondering when I will not be able to lock the van again.
Stevecrs
Postby kayroger » Mon Aug 31, 2020 3:41 pm
What fuse is for the awd system?
kayroger
Postby nigelk » Sun Jan 07, 2024 5:29 pm
Thanks for the answer to the interior lights fuse location.
I've replaced the blown fuse, but the new fuse has immediately blown :( Any hints or tips for finding the cause?
nigelk
Postby loot » Thu Jan 11, 2024 11:19 pm
nigelk wrote:Thanks for the answer to the interior lights fuse location.
The rear interior light switch can short out. If the fuse for interior lights is blowing, i suggest unplugging all 4 and then replace the fuse then plug in each interior light 1 by 1. I would maybe do the front 1 then both cargo ones then the rear front 1
loot
