MK 7) Fuse Details Fuse Box Location
Re: MK 7) Fuse Details Fuse Box Location
Postby Damien89 » Tue Apr 23, 2013 8:38 pm
ake wrote:
Damien89 wrote:Why is it called "battery saver supply"?
Because the interior lights are supplied through the battery saver relay.
Thanks again
Damien89
Postby loot » Fri May 31, 2013 4:19 pm
I am a retard!!!
fog lights.
I was looking at dipped beam and main beam and their fuses/ relays.
DOH!
next problem where are the fogs powered from? my rears work but don't appear to be any fuses/ relays marked up for them? also ids isn't showing a fault for them can anybody advise?
all fuses appear ok.
the only thing that resembles anything to do with fog is r15, please tell me it isn't that.
loot
Postby Damien89 » Fri May 31, 2013 6:24 pm
Is the battery saver supply relay the same fuse no.72? Or is it a totally different relay? If yes which it is?
Damien89
Postby ake » Fri May 31, 2013 8:13 pm
loot34 wrote:I am a retard!!!
fog lights.
DOH!
Relay R15 is for the daytime running lights (where fitted)
2 x 18 Custom 270 Trend
2 x 67 Custom 270 Trend
3 x 66 Custom 270 Trend
1 x 65 Custom 290 Limited
7 x 12 Transit 260 Trend
1 x 60 Transit 350
Or is it something worse?
Postby loot » Fri May 31, 2013 8:44 pm
aw I started removing r15 to put in my van, what do I do now then? I can't find any info on fog lamps:(
loot
Postby bigjohnthomas » Fri Jul 26, 2013 6:14 am
I can't see a fuse on there for the heated screen drivers side ?
Have I missed it?
Having to drive along leaning over looking out of the passengers side this morning
bigjohnthomas
Postby ake » Fri Jul 26, 2013 7:10 am
bigjohnthomas wrote:I can't see a fuse on there for the heated screen drivers side ?
Have I missed it?
In the per fuse box behind the battery under the drivers seat.
1 x 60 Transit 350
Postby bigjohnthomas » Fri Jul 26, 2013 7:19 am
Thanks ake no wonder I couldn't find the little git
bigjohnthomas
Postby gunnnell » Thu Aug 21, 2014 6:58 pm
Does the heater actuator have a fuse if so what is the number/position of it. Having problems with it got a second hand 1 today but unsure if this is working and could it be a fuse.
gunnnell
Postby loot » Fri Aug 22, 2014 5:13 pm
[quote="gunnnell"]Does the heater actuator have a fuse if so what is the number/position of it. Having problems with it got a second hand 1 today but unsure if this is working and could it be a fuse.[/quote]
Not sure what part you mean but the blower motor has fuse 55 in the auxiliary fusebox 40A
loot
Postby ake » Mon Aug 25, 2014 5:49 pm
Fuse 50 in the first box behind the glovebox. Should be 10 amp
1 x 60 Transit 350
Postby reevco62 » Fri Nov 21, 2014 11:18 am
Owned the van for 3 yrs now and never would have found that fuse box hidden behind the other one THANKS A LOT I mean it thanks saved me hours of head scratching and confusion.
Top write up needs pinning if not already a sticky
reevco62
Postby Airthies » Tue Dec 16, 2014 11:44 pm
So who's going to help me with a fuse? As one bits stopped clicking, I've now got a whirring going on... also a whine from the drivers seat and a racket in the back... anybody else blown a fuse lately? ;-) :-D :O
Airthies
Postby ake » Mon Dec 22, 2014 7:57 pm
Airthies wrote:So who's going to help me with a fuse? As one bits stopped clicking, I've now got a whirring going on... also a whine from the drivers seat and a racket in the back... anybody else blown a fuse lately? ;-) :-D :O
That sounds more like a dead front battery
1 x 60 Transit 350
Postby Airthies » Wed Dec 24, 2014 4:40 pm
Cheers ake
Found that all my problems disappear when I'm in the van on my own.... three kids in the back and the wife driving can cause all sorts of grief.... ;-)
Airthies
