What Engine Oil?
What Engine Oil?
Postby ake » Sun Jan 17, 2010 9:48 pm
The correct engine oil for Diesel Transits in the UK is 5w30 Semi synthetic
2 x 18 Custom 270 Trend
2 x 67 Custom 270 Trend
3 x 66 Custom 270 Trend
1 x 65 Custom 290 Limited
7 x 12 Transit 260 Trend
1 x 60 Transit 350
Or is it something worse?
Re: What Engine Oil?
Postby mercedes190d » Mon Nov 29, 2010 3:45 pm
is this for all tdct models and earlier models?
mercedes190d
Postby Altransit » Mon Nov 29, 2010 4:38 pm
TDCi, TDDi, TDi, and Di ..................... all of them!
Postby mercedes190d » Mon Nov 29, 2010 4:47 pm
does it matter what miles then low or high mileage? as previously told you use different grades for different mileages? how often should u change the oil? thanks
mercedes190d
Postby Altransit » Mon Nov 29, 2010 4:54 pm
That is the current recommendation from Ford, regardless of age or mileage. There is nothing to stop you using a slightly thicker 10w40 if you prefer.
The change interval will vary with the engine/model of the van, but i change mine (in the Di) at least every 10k miles.
Postby mercedes190d » Mon Nov 29, 2010 5:02 pm
thanks
mercedes190d
Postby M4tty » Sat Feb 05, 2011 2:23 pm
Hi mate do you know what oil to use in a 2005 2.3 petrol/LPG tranny please? Thanks
M4tty
Postby Altransit » Fri Aug 12, 2011 4:28 pm
Anthill_Rob wrote: I can get 15w40 semi-synth for €16/5l
That will be just fine in a Di
Postby Algert » Sat Jun 16, 2012 12:16 am
Dear all
Iam asking you for my ford transit,
What oli do you recomend me for:
Ford transit 2.0 tdi van
year:2003
km:230.000
I am using 5w30 but i am destryed e turbo till now
please tell me because is too urgent for me
thanks in advanced
Algert
Postby Altransit » Sat Jun 16, 2012 12:24 am
Algert wrote:Dear all
year:2003
km:230.000
Read the first post in this thread!
Postby Transit-Rich » Fri Jun 29, 2012 7:44 am
Hi,
Thanks for all the info,
Just to confirm - my transit is a 260 2l diesel.
5w30 Semi synthetic - is the correct type to get? Should it be ford branded or should I look out for any specific makes?
Transit-Rich
Postby ake » Fri Jun 29, 2012 12:59 pm
Transit-Rich wrote:Hi,
Any brand as long as it is to Ford spec
1 x 60 Transit 350
Postby Transit-Rich » Fri Jun 29, 2012 1:17 pm
Many thanks AKE :)
Just reading through the posts again and it seems there is a bit of confusion if we should be using full or part synthetic,
I am not worried about spending a little more on fully but do you think this is best personally?
I have used Magnatec type oil in my car so just looked at the Magnatec 5W-30 type for van, it says it has been recommended by Ford but only available in full - will this be ok?
Finally, 4l is the standard 'tub' size. Is this enough to do an oil change on a 2l 260 transit do you know?
Kind regards,
Transit-Rich
Postby ake » Fri Jun 29, 2012 2:52 pm
Either full or semi synthetic is absolutely fine, and if I remember correctly you need around 6 litres for a 2.0
1 x 60 Transit 350
Postby Transit-Rich » Sat Jun 30, 2012 11:05 am
Thanks AKE and apologies for all the questions;
I notice lots of transit filters come bundled with a spare 'sump plug', is it always best to replace the plug? Don't think i've ever had that on another vehicle.
Just to confirm procedure:
Get engine warmed up, park van on a slight decline with engine pointing down, take out sump plug, take off oil filter and replace with new, replace plug, fill with new oil.
Anything I have missed or any tips?
Many thanks,
Transit-Rich
