MK 7) Interior Light Fuse
Postby ake » Fri Feb 19, 2010 9:56 pm
The fuse for the interior lights on a MK7 Transit is fuse 72, 10amp
It is located in the hidden fusebox. See :arrow: viewtopic.php?f=40&t=49206 to help find it.
It is listed in the instruction book as 'Battery Saver OBDII'
2 x 18 Custom 270 Trend
2 x 67 Custom 270 Trend
3 x 66 Custom 270 Trend
1 x 65 Custom 290 Limited
7 x 12 Transit 260 Trend
1 x 60 Transit 350
Or is it something worse?
Re: MK 7 Interior Light Fuse
Postby craneman2010 » Sun Feb 21, 2010 1:45 pm
thanks AKE
craneman2010
Postby stevefirestorm » Sun Mar 27, 2011 7:10 pm
Many thanks for that,Would never have found it listed as battery saver.
stevefirestorm
Postby martynx » Mon Apr 09, 2012 12:18 pm
If you cant connect diagnostically, via the OBD socket , that fuse is the culprit as well !
martynx
Postby ake » Mon Apr 09, 2012 4:44 pm
martynx wrote:If you cant connect diagnostically, via the OBD socket , that fuse is the culprit as well !
The voice of experience Martyn :?:
1 x 60 Transit 350
Postby martynx » Mon Apr 09, 2012 4:52 pm
Yes I was miles away and clueless on Sus's old 110. I think I called Nitehawk and he saved the day ! :)
martynx
Postby speedsterOmari » Sat May 26, 2012 3:15 am
I've been finding some schematics for the fuse diagram and some details on its installation! I have come with this forum..thanks now I'll know the remedy for the electrical bug on my truck.
speedsterOmari
Re: MK 7) Interior Light Fuse
Postby Skipi » Wed Oct 22, 2014 5:40 pm
Thank you
Skipi
Postby DanIsADude » Sat Feb 28, 2015 5:57 pm
Holy thread revival Batman!
My new (to me) mk7 van, didnt have any interior lights working. After a small search on this forum, i found the answer, which has a big thank you attached to it for this thread.
However, one problem always creates another. Now my interior lights are always on in the rear of the van or when on the close with the door position.
Ive had a little mooch at the door shut mech on the slide door (Three little pins and a plastic plunger) and i just cant figure it out.
Am i just being a mong and missing something obvious? I can turn the two front lights off in the cab, but they stay on in both the forward and back switch positions.
DanIsADude
Postby ake » Sun Mar 01, 2015 11:52 am
How long have you waited for them to go off?
1 x 60 Transit 350
Postby DanIsADude » Sun Mar 08, 2015 12:08 pm
I would class it as a few moments. I got in the back of the van and shut both doors and waited 30 seconds or so, they were still on. Does it take longer than this?
DanIsADude
Postby tibsy » Sun Mar 08, 2015 3:50 pm
DanIsADude wrote:I would class it as a few moments. I got in the back of the van and shut both doors and waited 30 seconds or so, they were still on. Does it take longer than this?
about 30 mins!
tibsy
Postby Stangtastic » Mon Mar 20, 2017 2:20 am
Get in the back of the van with your keys in hand and shut the doors. Then deadlock the van. If the lights are working properly they should dim and go out when you deadlock the van. I did this to test some LED bulbs when I tried to make the lights brighter in the back but they didn't fully go out when I locked the van. They stayed very dimly let so they woulda caused a fault on the can-bus system. Went back to original bulbs for now...
Stangtastic
