Diagnostic Fault Codes DTCs
Postby ake » Fri Jul 16, 2010 7:55 pm
Here are some of the more common fault codes, if you know any others, reply to this thread and I'll edit them in :)
P0149 FUEL TIMING ERROR
P0234 turbo under boost
P0235 turbocharger boost pressure sensor A (MAP Sensor)
P0299 turbo over boost
P0335 Crankshaft Position Sensor A Circuit
P0404 EGR CIRCUIT RANGE OR PERFORMANCE
P0409 EXHAUST GAS RECIRCULATION SENSOR/CIRCUIT
P0704 clutch switch sensor
P0685 ecm/pcm power relay ctrl circuit/open
P1342 Loss of pedal sensor A
P1343 Loss of pedal sensor B
P1344 Loss of pedal sensor C
P1563 Injection Pump Control Module Requesting Engine Stop
P1564 Injection Pump Requesting Reduced fuelling
P1576 Total loss of throttle pedal position
P1608 Watchdog Malfunction / Internal ECM Malfunction
P1631 theft deterrent start enable signal not correct/ main relay malfunction
P1669 Injection Pump Control Module Monitoring ECM Fault
2 x 18 Custom 270 Trend
2 x 67 Custom 270 Trend
3 x 66 Custom 270 Trend
1 x 65 Custom 290 Limited
7 x 12 Transit 260 Trend
1 x 60 Transit 350
Or is it something worse?
Re: Diagnostic Fault Codes DTCs
Postby psv-hgv-flt » Sat Jul 17, 2010 8:15 am
psv-hgv-flt
Postby 391gonzo » Thu Nov 24, 2011 6:53 pm
po623 generator lamp control circuit
391gonzo
Postby 391gonzo » Thu Nov 24, 2011 6:54 pm
po325 knock sensor 1 circuit malfunction
391gonzo
Postby angeleye » Mon Feb 11, 2013 10:09 pm
i will stick this one for all
www.dieseltalk.com/support/DTC.pdf
angeleye
Postby karl » Mon Feb 11, 2013 10:40 pm
I'll put this up from my launch tech support site
http://www.launchtech.co.uk/dtc-codes-list/
karl
Tranny Lover!!!
Postby Altransit » Tue Feb 12, 2013 7:58 am
karl mcghee wrote:I'll put this up from my launch tech support site
These are not correct Ford fault codes :!: :?
Postby angeleye » Tue Feb 12, 2013 1:26 pm
viewtopic.php?f=2&t=124856
example
angeleye
Postby karl » Sun Nov 17, 2013 10:43 am
heres one a big file 48 pages of codes all ford pdf format
http://www.edgeproducts.com/product_ima ... pdf-41.pdf
karl
Tranny Lover!!!
