MK 6) fuse, relay and diode locations/ratings
Postby APH » Mon Aug 16, 2010 1:32 pm
APH
Re: MK6 fuse, relay and diode locations/ratings
Postby rob hood » Thu Dec 30, 2010 6:06 pm
great info just what i needed mate
cheers
rob hood
Postby davidlaird » Tue Jan 18, 2011 12:30 am
rob hood wrote:great info just what i needed mate
cheers
Me to. Thanks very much.
davidlaird
Postby TIMO » Thu Mar 03, 2011 1:58 pm
Nice one APH ..
TIMO
Postby valetman5467 » Thu Mar 03, 2011 10:37 pm
Thats fantastic guys , just what i needed
Many many thanks
Valetman5467
valetman5467
Postby 10.blaze » Thu Sep 22, 2011 12:25 pm
thanks just what i needed wud have spent days look for that
10.blaze
Postby Sachmo » Sun Sep 25, 2011 11:29 am
Thanks...
very useful. :-)
Sachmo
Postby KH_Towbars » Mon Feb 20, 2012 5:05 pm
Thanks mate, very helpful, didn't get a book with my van
KH_Towbars
Postby T350 DAVE » Sat Mar 17, 2012 4:27 pm
Exactly the info' I needed. Give the man who first posted this another beer.! All MK6 owners should view this as 'must have' information. The fuseboxes are an impossible nightmare guessing game without it. Thanks.
T350 DAVE
Postby TRAN517 » Mon Jun 25, 2012 4:25 pm
thanks just what ive been looking for
TRAN517
Postby melliwuk » Thu Jul 26, 2012 10:11 pm
thankyou VERY VERY VERY much!! saved my backside when my sidelight fuse went earlier!!!
melliwuk
Postby Transit-Rich » Mon Sep 24, 2012 6:28 pm
Thank you :)
I would like to know if it is best to replace fuses that differ from the guide with the stated ones.
I.e I have a couple of 20amps in 15amp slot and 10s in 5 etc.
Transit-Rich
Postby ake » Tue Sep 25, 2012 6:56 am
You should never ever fit a larger fuse than the ordinarily fitted one, however ford do change fusebox layouts from time to time, so this may not be fully accurate for your vehicle
2 x 67 Custom 270 Trend
3 x 66 Custom 270 Trend
1 x 65 Custom 290 Limited
7 x 12 Transit 260 Trend
1 x 60 Transit 350
Or is it something worse?
Postby Transit-Rich » Tue Sep 25, 2012 3:19 pm
Thanks AKE,
I have changed the fuses to reflect the sheet (all were lower class fuses except for the below).
I have a problem with 227 'radio ABS Mdule', it had a 3amp fuse in to begin with (which had blown) so I replaced it with the stated 5amp but that also blows.
Do you know what this fuse does and can you double check yours to see if the diagram is correct?
For some reason, before the fuse blows the oil light on dash stays on perminately. If I then use the power windows that 227 fuse blows??
Any help appreciated,
Richard
Transit-Rich
Postby wulliewinkie » Tue Oct 30, 2012 7:44 pm
they maybe all share a common ground/earth that could be faulty/corroded/short circuited to ground, check the wiring diagram to find if they share any circuits
or earths.
wulliewinkie
