MK 7) hunting/surging at idle, lacking power, p0089
Re: MK 7) hunting/surging at idle, lacking power, p0089
Postby Sharpy30 » Fri Jun 13, 2014 7:17 pm
Thanks will try getting codes tomorrow am hoping it's egr problem injectors were checked and ford said was ok just the seals , copper washers and few bolts were replaced ,av a mk6 tht does kind of same but new injectors never worked got egr blocked and never had problem for a year and now it's bk but it only cuts out randomly cld be 3 times 1 day then nowt for a week , so is it mainly tdci there's a prob with, cheers
Sharpy30
Postby ravin beef » Thu Mar 19, 2015 11:13 pm
Mine has started doing this in the last few weeks..
Here's hoping she makes it until she's traded in!
ravin beef
Postby loot » Sat Feb 06, 2016 11:36 am
Mine has started doing it if i start the engine and let it idle for a few mins, if i blip the throttle it goes for a minute and comes back.
Valves are about 1.5-2yrs old from Ford.
I'll investigate further at some point and possibly do another pump learn.
Bloody mk7s Lol
loot
Postby karl » Sat Feb 06, 2016 11:50 am
i have a 2013 coming in tuesday morning
but theses are not pump pilot learn as such its only a counter reset and use the updated fuel system
karl
Tranny Lover!!!
Postby ake » Sat Feb 13, 2016 12:56 pm
karl mcghee wrote:i have a 2013 coming in tuesday morning
Euro 5 self learn after resetting parameters with ids
Can cure idle problems and hunting
2 x 18 Custom 270 Trend
2 x 67 Custom 270 Trend
3 x 66 Custom 270 Trend
1 x 65 Custom 290 Limited
7 x 12 Transit 260 Trend
1 x 60 Transit 350
Or is it something worse?
Postby Harrygm » Thu Aug 03, 2017 5:33 pm
Cant i buy a ford ids machine to do it myself?
Sent from my SM-G955F using Tapatalk
Harrygm
Postby loot » Thu Aug 03, 2017 6:42 pm
Yes but forscan is free just buy the modified elm 327 15 pounds :-)
loot
Postby Harrygm » Wed Aug 23, 2017 7:50 pm
Sorry, what is forscan and modified elm? And where can i get these and do i need a laptop
Harrygm
Postby Harrygm » Wed Aug 23, 2017 7:52 pm
Is there anyone on here that can blank my egr, remap, sort out this prv issue if it is that, vans got a rattly grumble when im driving and its getting louder but dissapears if i engage the clutch when moving.
Anyone?
Harrygm
